Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
    Jan 2012
    17
    Default Another Syncrowave 180 SD Problem Thread! No Amperage Control!
    Well I was just going to buy a new Diversion 180 but I found a good deal on this syncrowave 180 sd and decided to buy it even with the known problems of the boards going out. This one with only 16 hours on it and is a 04 model looks to have the common board failure.
    I come home with it after testing fine before I bought it and wired a new plug at the end since the previous owner had it hard wired. So I turn the machine on today and turn it to DCEN, put a new tungsten in freshly ground, and start to weld 1/8 mild steel plate. Im set at 120 on the amperage and start to weld. NOPE. All I get it HF start and thats it no amperage control. Machine says 120 still with moving the pedal to all of the way either direction. I switch to my finger control and same results. Also I heard the HF kinda cutting in and out in the machine so I pull the side cover off and look and it is kinda sputtering during HF start. Also Voltage says 14.7 when hf comes on and does not move with pedal. Not sure what is going on here but sounds like a bad board. And I checked the gaps and they were good. Inside of the machine is very clean and no noticable problems.
    Any ideas on what to check or test?
    Jan 2012
    17
    Was messing with it again and found the gas was not flowing to the cup either. Wow. 16 hours on this machine and its so messed up I could only imagine what happens at 100 hours.
    Nov 2010
    265
    Quote Originally Posted by 417Diver View Post
    I am sure we will get to hear about that too...
    Oct 2004
    Edmonton, Alberta
    8,012
    16 hours huh, how many cycles?
    Jan 2012
    17
    checking cycles. I am assuming that the hours/minutes are not the actual time on the machine and the cycles are?
    Jan 2012
    17
    Quote Originally Posted by Dipsomaniac View Post
    Thanks for being a smart ass...
    Nov 2010
    265
    Perhaps, but I do think that your original post is presumptuous at the very least based on what you think are the facts concerning this unit.
    Jan 2012
    17
    Well the fact is that the machine is inoperative. This seems to be very common for the syncrowaves and maybe I was incorrect on the timer but I still have the right to be upset over the quality of these machines. Maybe if someone gave me a suggestion on what steps to take to fix it I would be in a better mood about the situation. I have read the other posts about checking if the machine will stick and to replace the Halls Device but I am just wanting to know if there are any other things I should look for. Anyways I will just take the machine to airgas Monday and enjoy the bill when I get it.
    Thanks for the HELP!
    Cycles 002 237
    Nov 2010
    265
    Cycles 002 237
    So, you want to claim that your machine was cycled 2237 times for the 16 hours it operated in the past 7 to 8 years for an average cycle time of approximately 26 seconds?
    Also, explain to us in detail how you checked this unit out by "testing" it and why you changed your mind on the purchase of a brand new Diversion when you claimed you knew that this Syncrowave wasn't a quality buy?
    I am very interested in your claim that you want help in fixing this but you have also claimed to know what is wrong with the unit any way. Perplexing, isn't it?
    Last edited by Dipsomaniac; 01-28-2012 at 10:30 AM. Reason: Misspelled Diversion...LOL
    Oct 2004
    Edmonton, Alberta
    8,012
    Serial # perhaps would be helpfull
