Results 1 to 2 of 2
    Dec 2012
    1
    Default Question: Can I run a Super S-32P Wire Feed on a Dynasty 300?
    I have a sweet Dynasty 300 that I use for TIG... Love it.
    Found a nice 'Super S-32P' suitcase wire feed, and would like to use it with this welder.
    Are they compatible?
    Thanks ahead of time.
    Jeff
    Oct 2004
    Edmonton, Alberta
    8,177
    Yes and no, as its a voltage sensing feeder, then your wire will be spray in CC, so likely a dual shield wire would be your best bet. Since the S32 doesn't have a built in contactor, (was an option though) you'd have to break away from the arc, Is it worth it, probably not.
