Results 1 to 3 of 3
Thread: welding 4140
    Jan 2012
    Default welding 4140
    I am repairing some farm equipment..have to tack weld a strip of 4140 (1/4x3/4x12") to mild steel for a wear strip..I have a stick welder and use 7018 as a good unversal rod..Not sure if it will work for 4140? Just a small project so didn't want to buy large quanities of eletrodes that will just go bad..
    Just a farmer
    Lodi, CA
    1,307
    7018 is the correct rod to use.
    Jan 2012
    Thank You...There is so many special rods, alloys, and etc. out there make things confuseing. My head has't got room for the complicated stuff.
    Thanks again..
