Results 1 to 2 of 2
Thread: table
    Default table
    Does any one have plans for a nice welding/fabricating table
    WY...armpit of U.S.A.
    659
    If you care to use the 'search' feature here, you'll undoubtedly end up with more ideas than you can incorporate into ten welding/fab. tables. Also, try checking out the 'Go to Welding Projects' section on the right of the screen for short write-ups and pictures of similar projects. As far as specific plans with measurements and such included, you may have a bit more difficult time of it. Still, reference a photo with some other features or tooling on it that can be scaled to approximate the table dimensions and you should have a near match...or just go with your own set of dimensions mandated by your height or other physical or job specific needs.
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
