Results 11 to 19 of 19
Thread: band saw?????
    721
    Piniongear,
    That video was excellent. Thanks for sharing.
    10
    I have a Porter Cable and I'll be looking for some mounting holes tomorrow. I love the saw, btw, I have had it for 10 years and have had to do nothing to it but change the blades.
    Sep 2010
    Las Vegas, Nevada
    6
    Default Milwaukee Bandsaw
    I use a Milwaukee Bandsaw, brand, reputation, reliability, and use of tool, not only for hand cuts, but for bench mounted, see attached (jpg.)
    "Build and Weld"
    Miller02
    Miller Cricket XL
    Miller Millermatic 140 Auto Set
    Miller 180 Mig
    Miller 211 Mig
    Miller 252 Mig
    Miller Millermatic Passport
    Miller Syncrowave 180 Tig
    Miller Maxstar 150 Tig
    Miller Diversion 180 Tig
    Miller Spectrum 125C Plasma
    Miller Spectrum 375 Plasma
    Miller Spectrum 625 Plasma
    Lincoln AC/DC 225 Arc Stick Welder
    Dec 2011
    Illinois
    87
    Yes I definitely agree, I am currently using my buddies milwaukee and I realy like it will be looking to buy one soon.
    Clarksville, TN
    427
    I have a Milwaukee Portaband, the only complaint is the top handle shattered while in the case early in its life. I've had it for about 8 yrs, 7 and change without the top handle. It is still pretty easy to control without though, so I never bothered trying to find or make a replacement.
    South Carolina, Dixie
    515
    Cool Porta band
    I've got both a Milwaukee and a Porter cable. The milwaukee stays in the work trailer most of the time and the Porter Cable is on the truck. Either way, they both work well. But do your homework. Best to buy a better tool once, even if it costs more. Buying Hobo freight stuff just doesn't "cut" it for me.
    Mustangs Forever!
    Miller equipment.
    Jun 2012
    3
    For the portable band saw machines, consider Trajan, Jet and Dayton brands. They come in various machine models (depending on your needs) and also in fairly reasonable prices.
    May 2009
    Central North Carolina
    142
    I recently purchased a new DeWalt Portaband and soon found that I frequently wished to use it as a stationary band saw. While deciding how to make a table and stand for it I found that SWAG Offroad makes several versions of tables and stands to fit these saws. Their design seemed far better than what I had planned to build, so I purchased SWAG's V3 table/stand from their website.
    With the version 3 a small square table bolts onto the saw in place of the DeWalt supplied narrow table/strip. This new table then fits closely into a U shaped cut-out in a larger table/stand when needed for bench use. The design allows for the the saw and the small table insert to be easily removed from the table/stand for portable use and then quickly and easily replaced back into the table/stand when needed for bench use. The table/stand comes with miter gauge slots on both sides of the blade that allow a standard miter gauge with a 3/4 X 3/8 bar to be used with it. This works OK, but I've found that I use the miter gauge more as a push block than I do for precise miter cutting.
    I'm very pleased with how well the saw and stand work together. They have proven to be very handy for cutting out small parts. My only wish is that SWAG had provided a rust preventive finish on their product because here in the Southeast unprotected steel rusts very quickly. I have to remember to oil it before putting it away or I will be sanding the rust off the next time that I want to use it.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    I guess you have a pretty good looking saw in your shop. Donít forget to put coolants or lubricants to maintain its beauty and preserve your blades. I am using AF2000, a semi-synthetic solution that cools and lubricates extending tool life. It would surely avoid rust from eating your saw.
