Results 1 to 10 of 19
    Jan 2012
    Default Aluminum Boat Gas Tank?
    I'm going to build a new gas tank for my boat. I not really sure what thickness of aluminum to use. The gas tank will hold 12 gallons of fuel. Any Suggestions?
    3,961
    Are you going to TIG or Mig it?...Bob
    Jan 2012
    Default tig
    i'm going to tig weld it
    Lake of the Ozarks MO
    3,594
    YUP
    use 5052 at least .100 thick and weld it with 5356.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Jan 2012
    Kansas
    85
    Round or square? Square I'd go a little heavier than round. I like to go a little heavier than needed so maybe .125 5052 if square or even round. My 2 cents
    I would use .125 with the gas tank and also TIG and mig weld it with and bondo the edges. You need to test it for leaks before hand.
    1,919
    Quote Originally Posted by bostoncanadawelder View Post
    So you would tig it, mig it & bondo it? Seriously?
    Fusionking is correct, but you can use .125" also if it is easier to get.
    May 2011
    Bossier Parish La.
    560
    Is this going to be a portable tank or a permanent install? If a permanent install, I would go as large as practical, as boats tend to burn fuel at a pretty good rate, and the more fuel you have the longer you can stay out on the water. But a portable tank starts to get pretty heavy after 12 gallons. Gasoline weighs about 6Lbs. per gallon, so your looking at 72 Lbs, plus the weight of the completed tank. Go over all your welds very thoroughly before adding fuel. Even if you test for leaks with water first, be aware that gasoline molecules are smaller than water molecules. Meaning if, even though it doesn't leak with water in it, don't mean gas won't find a small pinhole if there is one. Double or triple check it for leaks after it's filled with gas. After filling with gas it will be too late to go back and do anymore welding W/O serious purging effort and major cleaning, which might not get out ALL fumes. BOOM BIG TIME.
    Even BONDO may not hold up as a permanent fix when exposed to gasoline for extended periods, check it often in the BONDO area if you end up using it. Does anyone on here KNOW(not just THINK it does) if BONDO will hold up to exposure to Gas?
    Deltaville, VA
    2,239
    Typical thread.
    OP asks a question and gets an answer from a "pro" who knows what he's talking about and gives the correct, detailed explanation.
    Then the "peanut gallery" chimes in with a bunch of mumbo jumbo BS (mig, tig, bondo----yeah, right) and a bunch of other irrevelant crap.
    Just confirms the old statement:
    If you can't dazzle them with brillance, you can baffle them with bullsh1t.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    canada
    66
    Bondo??? What is that all about and then mig as well as tig??This needs clarification! "LOL" Sorry "TOO MUCH BS".
    R
