Results 1 to 7 of 7
Thread: Trailer Project
    Dec 2011
    4
    Default Trailer Project
    Here are some pictures of my latest welding project. I am building a 83"x14' dual atv trailer. I got most of my insperation from a BigTex Trailer model. The frame is 3x2x1/4" angle with 2x2x3/16" crossmember 16" O.C. I used 3" x 4.1# as the tongue and wrapped it around the frame to the spring supports. The rail is made of 2x2x1/8" and the two removable side ramps are made of 2x2x3/16" sides with 2x2x1/8" rungs 8" O.C. The weather turned cold fast so this is as far as i have gotten. I still have to build the rear gate/ramp ,brackets for light, primer, paint, ect.20120115_113424.jpg
    Dec 2011
    4
    Dec 2011
    Illinois
    87
    The trailor looks great, keep up the great work and lets see more picts. as u go. There is nothing more gratifying than being able to say you built it with your own two hands! I realy like the lay out of your place there to.
    Jan 2012
    Kansas
    85
    Cool trailer looks good. I have to ask though how you are welding it outside. I mean I see a gas bottle on your MIG. How are you keeping gas coverage?? I live in Kansas and could never run MIG with gas coverage outside. Just curious.
    Dec 2011
    4
    I am using flux core wire for the welding outside. The two ramps i build inside my shop so i swithced back to mig for those.
    Dec 2011
    4
    Latest Progress:
    I got the rear gate welded together and mounted to the hinges. All the light brackets are set along with the fenders. I have the tiedowns welded to the sides but did not get to the front yet. 20120129_150100.jpg20120129_150112.jpg20120129_150130.jpg20120129_150145.jpg
    Jan 2012
    Harrisburg, PA
    43
    Nice work. Should last many years.
