get drum deheader,no sparks
Results 21 to 30 of 64
Thread: Oil drum cutting
06-07-2011, 05:56 PM #21
- Aug 2010
- stratford ,CT
- 2
06-13-2011, 10:27 AM #22
detcord works great to cut drums
My father used to do it alot
Backed my CATMA over your CARMA
OOP"S clumsy me
What would SATAN do ??
Miller Digital Elite (new)
Jackson EQC master (old)
Miller Trail Blazer 302 Air Pak
Spectrum 625 Extreme
Suitcase 12RC
Evolution Rage 3 saw
Craftsmen Atlas 12X36 Lathe
Half a ton of tooling
Rusty old truck
06-14-2011, 10:01 PM #23
- Jan 2009
- Whitehorse, Yukon
- 280
Take both bungs out and cut away. It may flash a little but won't explode. If you're really unsure about it, then purge the drum with argon or nitrogen before AND during the cutting process. Displace all the oxygen and you eliminate the possibility of an "earth shattering kaboom". Or, fill the son of a **** right to the brim with water and hack away with an O/A torch and it won't go poof.
If a qualified welder can do oil well abandonments and hot tie-ins on pipelines, I'm not gonna lose any sleep worrying about lopping the top off of a stupid 45 (yes, 45) gallon drumLast edited by wronghand; 06-14-2011 at 11:42 PM.
Big Blue 400D
Trailblazer 302
Miller S-32 suitcase
12VS suitcase
Lincoln LN-7 (BIG suitcase)
Victor torches
Lincoln 350MP with 35' push-pull gun
Lincoln PrecisionTIG 375
Spectrum 1000 plasma cutter
06-15-2011, 06:54 AM #24
Member
- Jan 2011
- Nolalu (near Thunder Bay) Ontario, Canada
- 41
I showed my wife. Take an unlit torch, lean over tank or barrel, support elbows and look down. See where your stomach is? All your vitals are right there when it blows. No wonder people die
Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
06-15-2011, 09:15 AM #25
Read Brad Livingstons bio and watch the movie "Just a Second Ago". Something to think about even for a job that you have done 100 times before with no problems. Treat every tank, drum, and job different because no two may be the same...Bob
http://bradlivingston.com/bio.htm
http://bradlivingston.com/stream.htmBob Wright, Grandson of Tee Nee Boat Trailer Founder
06-18-2011, 10:35 PM #26
STOP### STOP### STOP###
An 18 year old boy was killed when he tried the very same thing this week.
It was a 50 gallon drum which had peppermint oil in it previously. He was using a cut off blade .
It was a Catholic High School and the boy was in a shop high school class under the supervision of a shop teacher apparently unaware of the danger.
Happened this week I believe.
See www.weldingweb.com http://www.cbc.ca/news/canada/ottawa...n.html?ref=rss
Buy a tool made for opening 50 gallon drums. It is like a giant can opener.No sparks,no heat.Last edited by Donald Branscom; 06-18-2011 at 10:38 PM.
06-19-2011, 07:21 PM #27
Death by 55 gallon drum
A laborer working for a Concrete Resurfacing Company was killed when an EMPTY 55-gallon drum of Concrete Sealer exploded and engulfed him in flames. It is believed that the laborer was attempting to cut the empty drum open with a cutoff saw just prior to the explosion.
The laborer was burned beyond recognition. The Concrete Sealer was 80% by weight ethanol and methanol. It is used as a treatment for concrete surfaces to make them water-repellant. On the day of the explosion, the Concrete Resurfacing Company was repairing a parking garage.
In another incident 10 years earlier on almost the exact same Concrete Sealer product, another laborer for a Highway Repair Company was cutting the lids off of used 55-gallon drums so the drums could be used for refuse. He was using either a torch or an electric welder to cut the lids off. The procedure was believed to be inherently safe, as they would turn the drums over for several days to let any flammable liquid drain out, and then they would turn them upright and fill them with water and let them stand for five additional days before any cutting.
In this second incident, the Concrete Sealer drum was not being cut open. However, it was standing next to another drum that was being cut open when a spark flew from one drum into the other. The drum exploded and the laborer died within 24 hours. He suffered third degree burns over 80% of his body.
In both cases, the fuels for the explosion were ethanol and methanol vapors inside what were believe to be empty or near-empty drums. It turns out that the vapor pressure of a small amount of liquid is just enough to fill the entire 55-gallon drum with an explosive mixture of air and flammable vapors. Therefore, near-empty drums can be significantly more dangerous than drums that are full.
The average worker perceives the risk of a near-empty drum to be less than a full drum. Because the actual risk is counter-intuitive, it is essential that drums of flammable liquids prominently warn of the high explosion risk of a partially empty drum. Additional warnings against cutting or welding are needed, as well as instructions to avoid all ignition sources and keep the drum completely closed at all times. While employee training about the risks of near-empty drums can be beneficial, used drums all to often find themselves in the hands of untrained employees or untrained non-employees. This reinforces the need for adequate and eye-catching labeling that goes beyond the usual warnings for a flammable liquid. The average, untrained layperson intuitively believes that less liquid means less risk, when the opposite is true.
This case involved:
• The OSHA Hazard Communication Standard,
• Flammable liquids,
• The vapor pressure of flammable liquids,
• Human Factors,
• The adequacy of MSDSs, and
• The adequacy of labels.
Dr. Fox is an explosion expert, fire expert, and chemical expert with extensive experience in OSHA chemical regulations and chemical safety.
06-19-2011, 07:51 PM #28
- Mar 2009
- Red Deer, Alberta
- 19
fill with water and use a sawsall ! Remember oil, gas, wood etc does not burn.......when heated the vapours off them burn!
06-21-2011, 05:05 PM #29
- Dec 2010
- 2
Jig saw with bi-metal blade is safe and makes a nice smooth cut!
06-24-2011, 05:22 PM #30
