Results 1 to 2 of 2
    Jan 2012
    Harrisburg, PA
    43
    Default My Wood Processing setup
    I acquired an old, super heavy, 3 pt hitch log splitter a few years ago. It only could be operated from the hydraulic lever on the tractor. I modified it by adding an axle, spool valves for the hydraulics, a retractable tongue so I can haul the thing with my 'Buzz Saw' attached. At first I had no log lift, but added that last year. The buzz saw was completely redone. Installed the safety guard around the blade, added a right angle gear box, pto shaft (was originally driven with a flat belt, then a small engine was added), beefed up the frame, etc. Thing works great.IMG_1230.JPGIMG_2207.JPGPicture 020.jpg
    Fallbrook CA
    20
    Nice looking setup; well done
    Harold
    Harold
    Craftsman Colormatic AC
    Victor Journyman Setup
    Syncrowave 180 SD
    MM210 With Spoolgun
    Dynasty 200 DX
    Spectrum 625 Plasma Cutter
    Miller HD Tape Measure
