Couple of pics of a mini excavator dozer edge i did last week for a customer.The edge is 5/8"thk x6"wide 60"long.Mig welded it with .035 70s6 .Preheated a little to slow the cooling.
Results 1 to 10 of 11
Thread: Cat 303C Dozer Edge
01-08-2012, 09:27 AM #1
Cat 303C Dozer Edge
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
HT/PWR-MAX1250 PLASMA
01-08-2012, 10:12 AM #2
Is the beveled edge not supposed to be on the bottom?
252 Miller Mig
180 Synchrowave
R - 45 Milling Machine
Kingston 1100 Lathe
Miller 2050 Plasma Cutter
01-08-2012, 12:22 PM #3
No the thick edge down on this.If i was welding it into a bobcat bucket the the thin edge would be forward.This is weldable bucket lip i use for doing this.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
01-10-2012, 05:58 PM #4
- Dec 2009
- Williams Lake, British Columbia
- 718
I think the bevel should be at the bottom as well. All the blade edge I'v done the bevel had to be at the bottom. Maybe the little blades are different.
01-11-2012, 04:57 AM #5
The beveled part is about 1-1/4" so when it wears,which would be quick with the thin part you are now into the the thicker section anyhow.The blade is 3-1/2"below the push board.Do it anyway you like, this is how i,ve done them for 10+ yrs have not had a complaint about it yet.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
01-11-2012, 05:56 AM #6
- Apr 2009
- Upstate SC
- 129
A blade like that is used mostly for pushing and there is no need for a sharp edge.
CGOld Miller Swinger 180 Buzzbox
Miller Diversion 165
Smithy Lathe/Mill
01-11-2012, 07:15 AM #7
01-11-2012, 04:43 PM #8
- May 2011
- Belgrade, MT
- 25
blunt end
One nice thing with the blade like that, back dragging would be very nice. Never seen a blade like that on the mini's, most seem to round out on the bottom and is left that way. One thing I am wondering, how big of a gap is that between the end of the blade that you installed, and the edge of the mini's blade?
01-11-2012, 06:23 PM #9
This will round over more with wear.The old edge is cut off before installing this one if thats what you are refering too.
BB402D
TB300D
DIMENSION652
MM250X
MAXSTAR140
01-12-2012, 06:39 AM #10
- May 2011
- Belgrade, MT
- 25
