Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
    Jan 2012
    Kansas
    85
    Default Dynasty 350 remote button
    Just purchased a Miller Dynasty 350. What i'm needing is a remote button on the torch. I want is a set up to where when the button is pushed and held down the arc is on and when let off it is off. Can this be done and wired in??? What parts do I need??? Thanks
    Nov 2003
    3,588
    Default Rms-14
    What you want is an RMS-14
    RMS-14 Remote On/Off Control (14-pin plug)
    Momentary-contact switch for contactor control. Rubber-covered pushbutton dome switch ideal for repetitive on-off applications. Includes 26.5 ft (8 m) cord and 14-pin plug.
    (For all Miller solid-state power sources after serial number JK674521.)
    187208
    http://www.millerwelds.com/products/...ccessories.php
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Jan 2012
    Kansas
    85
    So I will have to unscrew the plug every time I go from foot pedal to button?? Is this correct?
    Nov 2003
    3,588
    Wink
    Quote Originally Posted by corbyndad View Post
    Correct....
    2T 3T 4T Remote Trigger Operation is on page 66 of the manual... starting with diagram 6-4
    http://www.millerwelds.com/om/o216869aa_mil.pdf
    BTW You will just Love that DYN 350.... !!!!!
    My Blue Stuff:
    Jan 2012
    Kansas
    85
    Thanks for your help H80N!
    Dec 2011
    S.W. Michigan
    19
    160+ dollars. I always just make mine for about 25. Much less if you don't want it seperate from pedal connector. I've used doorbells old mig gun triggers etc. You can piggyback your trigger connection to your pedal so you can use either. Just depends how pretty you want it. I just use small gage 2 conductor control wire. You can get connector components from digikey or buy complete connectors from ssc controls.
    Nov 2003
    3,588
    or you might look into the WeldTec switches...
    http://tectorch.com/control%20switches.htm
    there are probably others as well...
    had thought SSC Controls had them... but could not find them on their site...
    My Blue Stuff:
    8,252
    I like the triggers out of a bernard mig gun, a cable and a 20-27 male 14 pin amphenol, otherwise I use a rubber covered button out of a T-dyne plas torch
    Merely use a 2 wire 20 gage cable and solder pins "A" & "B"
    Jan 2012
    Kansas
    85
    So your saying if I wire one side of the switch to the A pin and one to the B pin I'll have a push and hold ON and release OFF in the standard mode??
    Nov 2003
    3,588
    take a look at fig 4-13 page 34 of the manual (pg 40 of PDF)
    My Blue Stuff:
