Results 1 to 2 of 2
Thread: Packmaster 50
    Jan 2006
    Ontario
    17
    Default Pakmaster 50
    Anyone heard of this type of plasma cutter? if so any good? any info would help, thanks. cut size? duty cycle? any info...
    Jan 2006
    Ontario
    17
    Default pak master 50
    70 is the duty cycle, 1/2" cut capacity, not a bad unit if i do say so. only fall back is it's got a plastic housing.
