Page 1 of 3 123 LastLast
Results 1 to 10 of 25
    Default Metal brittle after welding
    I am manufactiuring a special post driver tool and am having a bit of trouble with the metal being brittle after welding and will snap off like a toothpick instead of bending like most metal will. It is mild steel-angle iron and 1 inch square tubing. There is vibration when the post driver is in use from all the pounding. I am wondering if the metal I am getting is not consistent in the carbon content and I am getting brittleness from the welding heat and I need to normalize and anneal the metal? Anybody got any ideas? Anybody having any trouble with the metal they are getting lately? Check the video and see the pounding I am talking about
    Thanks Virgil Johnson
    www.trailpostdriver.com
    Added-
    I am using a solar wire feed 130 amp running max amps .035 wire general purpose wire and 75/25 argon co2 gas no water quenching only air drying after welding.
    Here is a couple of pictures. I am now using a 3/16" wall tube and hope that will take care of the tube and I need to go with a thicker angle iron next batch. But I think I need some normalizing or annealing or maybe specify the metal type when I buy it I am not sure? The fails were by a weld
    Thanks Virgil
    Added- This is not bed frame the angle was typical angle you buy at the metal shop
    Nov 2003
    3,690
    Virgil
    first of all "Welcome Aboard"...... this place is a bag of mixed nuts... but I expect that you will sort the wheat from the chaff...............
    could you post some pics if cracks ans failures??...............
    also welding Process?? MIG?? filler wire type?? shield gas???
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Default New pictures and info
    Here is a couple of pictures. I am now using a 3/16" tube and hope that will take care of the tube and I need to go with a thicker angle iron next batch. But I think I need some normalizing or annealing or maybe specify the metal type when I buy it I am not sure? The fails were by a weld
    Thanks Virgil
    Nov 2003
    3,690
    Default more questions???
    pure argon on steel???? should be 75/25 Argon-Co2 or straight Co2 for mild steel.... not straight Argon....
    What Grade and Brand of wire??? (ER70-XXX...???)
    That angle iron looks suspiciously like old bedrail.... if so... it is hardened high carbon spring steel........ Brittle as glass on repeated impacts.... if it is recycled bedframe.... that would be the bulk of your problem....
    My Blue Stuff:
    Lodi, CA
    1,313
    Doubt it is a weld issue, mild steel just doesn't get that brittle under normal fabrication methods. More likely to be a design/engineering problem. Post up a picture of the whole item, with an arrow pointing to the location it is breaking.
    Dec 2010
    374
    are the cracks on the angle iron ?is so i bet your probably useing 1/8th thickness angle iron .i have some in my shop and it's not really good to use i have had a few welds just rip right out of the angle. if your useing a thicker angle iron then i would think it might be your welding the thing up without taking a break and your over heating it that would make the metal brittle and break. i fabricate alot of small stuff and what i do is weld a little bit on one and then jump to the next and hop around i never weld up one piece at one time because it's just to much heat .like the others said we need pictures of the cracks and also your welding process would help to determine how hot your getting the metal. also like what the other member posted pure argon is not the gas you should be useing.
    Default new picture
    Sorry it is 75/25 argon c02 not sure about the wire just bought it at the welding store and I said I wanted general purpose wire and got FIREPOWER general purpose wire. It was not bed frame and I know what you mean about bed frame hard to drill and is brittle. I posted a new picture with areas that failed
    Thanks Virgil
    Aug 2010
    La Habra, CA
    60
    Make sure your using a gas mix. Also step down in wire to .030 because I don't think your machine has the muscle to truely burn .035, so you may not be putting down a good weld. It does look like the material is tearing thought so maybe thicker is better.
    Default new picture posted
    I posted a new picture with failed points
    Thanks Virgil
    Jul 2011
    162
    Looks like failure in the angle iron HAZ. Probably foreign steel.
    Switch to domestic material with S6 filler and C25 shielding gas.
Tags for this Thread
