Results 1 to 7 of 7
    Dec 2011
    15
    Default Bobcat 250 not welding
    My bobcat 250 will not weld but has generator power. The previous owner tried to replace the 5 position polarity switch and has hooked it up incorrectly because it sparks terribly when I move the switch back and forth. I have looked at the wiring diagrams and it seems to look correct. Could it be anything else or am I correct in thinking its the polarity switch?
    Aug 2008
    Orange, TX
    1,216
    If the range selector switch is hooked up wrong as you've stated then it needs to be corrected. If it's hooked up wrong, how can it look OK?
    Is the engine "laboring" as if under a load?
    You're going to have to figure that part out before you do anything else and if it's arcing when changing positions, I highly recommend you don't do it or you'll be replacing it again.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2011
    15
    It looks like it is hooked up correctly from the wiring diagrams on the inside of the side panels And yes, the welder acts as if it is under load. It looks like the previous owner just removed the cables from the 5 position switch and not the rest of the welder. Thanks for the reply Duane.
    Dec 2011
    15
    Is there a picture or diagram better than the ones in the owners manual or inside the welder I can use to make sure the switch is correctly wired?
    8,197
    To pull up the correct diagram, we'll be needing that Serial#. however your machine is under load, likely the weld stator has a short, or rectifier is pooched but we'll figure it out.
    Dec 2011
    15
    Slept on it and went back this morning and figured out the problem. There was a couple of wires that were hooked up wrong on the switch causing unintended load. Thanks for the reply and help!
    Aug 2008
    Orange, TX
    1,216
    Congrats on the fix and thanks for reporting back to let us know.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
