Results 1 to 5 of 5
    Jun 2012
    Harvest, Alabama
    2
    Default WTB 2 and 4 inch rings
    I have a couple of projects, and I'm looking for 2 and 4 inch steel rings from 1/4 inch round bar, I need 24 of each size.
    check out king architectural metals they have decorative rings for fencing and gates
    Oct 2007
    Cave Creek Az
    1,080
    Contact your local blacksmith. I can't tell you how many rings I have made over the years. If you have a torch they can be made fairly easily. I would do it, but am still somewhat backlogged at the moment.
    Salem ,Ohio
    3,964
    Cool
    Quote Originally Posted by walker View Post
    I have a powered ring maker that uses 10' barstock at a time then cut then to a ring but zero time...Bob
    Mar 2011
    st-eustache qc.canada
    259
    Default if they are only for ornamental...
    get used springs from overhead doors and cut them parallel to the lenght with a zip cut.
    again not for structural use ...tempered steel that is
