Results 1 to 9 of 9
    Dec 2011
    5
    Default miller high frequency hf-251-d1 tig problem
    hi, i just purchased a hf-251 tig atachment for my trailblazer 250.
    when i turn the power on the hf unit the gas flows and does not stop.
    just wondering if anyone knows why.
    thanks keith
    Nov 2003
    3,508
    first thing would be to download the manual for your serial number unit.... from there go to setup config, and switch settings, troubleshooting.. etc....
    http://www.millerwelds.com/service/ownersmanuals.php
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Millermatic 200
    Dec 2011
    5
    i have the manual but it does not have anything about the gas flow. there is no knob or adjustment on the unit for it.
    Nov 2003
    3,508
    From what I can see of the manual... that unit has a fixed 15 second postflow timer.... is it going longer than 15 seconds???.... study your manual.. and schematic.. is the gas solenoid still energized with 24vac after that time period???
    My Blue Stuff:
    Millermatic 200
    Dec 2011
    5
    the sylonoid stays energized as long as the unit is on.
    Nov 2003
    3,508
    you may have a problem with TD1 time delay... leaving GS1 solenoid energized...
    My Blue Stuff:
    Millermatic 200
    Dec 2011
    5
    thanks i will check out the td1 relay.
    Aug 2008
    Orange, TX
    1,216
    Have you timed it? 15 seconds is a long time when you're waiting. Mine actually runs for ~18 seconds.
    FYI, others new to the HF-251D have thought they had a problem until they waited long enough for the timer to time out.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Dec 2011
    5
    took it apart last night and i think the timer is bad. ordered one wit adjustable time delay to go back in. thanks for the replys. will let you know if it works.
    keith
