    Dec 2011
    Default Sears torch repair: What material should the o-rings be made from? What Harris model?
    I have a model 313.54406 Sears torch handle and a model 313.54408 Sears cutting torch. It was really made by Harris. Does anyone know the corresponding Harris model numbers?
    I'm asking because the the o-rings on both the welding and on the cutting torch pieces need to be replaced. With the Harris model numbers, I could order new ones.
    I can probably figure out the sizes even without the Harris model number, but what should the o-rings be made from? What materials are safe with acetylene & oxygen?
    Nov 2008
    Atl, Ga
    371
    This is who I go to for torch/regulator rebuilds:
    http://www.regulatortorchrepair.com
    Maybe call and ask?
    2007 Miller Dynasty 200 DX
    2005 Miller Passport 180
    Mar 2010
    488
    Torch O-rings are usually made from durable Viton or similar, but they are cheap so no biggie.
    Dec 2011
    Ok, thank you both!
Tags for this Thread
