Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    Dec 2005
    Dallas, TX area
    267
    Suggestion...........use it doubleline. It will slow the travel speed, double the lift capacity, and most importantly, it will hold more weight without the winch
    unwinding as they will under a heavy load.
    Double lining the winch doesn't double the capacity, it cuts the workload on the motor in half. The line will only hold so much, the mount and hook likewise.
    HTH
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
  2. #22
    Raymore Missouri
    1,925
    Quote Originally Posted by triggerman View Post
    HTH
    As compared to single line pull, yes it does. I was not talking about the cable, the mount, snatchblock etc. I doubt his 2000# winch could even get close. That's probably for a rolling load and just about anyone stating pulling specs for a winch is talking
    first layer on the spool..........it goes downhill fast after that. Also you better have a good voltage supply, cables, connectors.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
  3. #23
    Feb 2006
    411
    Thanks for the info guys . looks like I will have to stop by the harbor freight store
    you can wast alot of time in their
    Thanks again
    ...... Richard
