Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2005
    Dallas, TX area
    267
    Default New project pics
    I finally broke down and bought a bender. 100% of the materials for the stand were scrap I had picked up.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Thumbs up
    verry cool.
    cant wait to see what ya make with the bender.
    Raymore Missouri
    1,906
    What stops it from spinning on the floor? I have a bender I made (in the project gallery) mounted to a 4x4 ft table with 3/8 steel top, 4 3"sq legs x 3/8" wall, with a shelf 10" off floor same size as table, a 6" vise mounted, a 30"' shear/brake/roll plus other heavy stuff and until I bolted it to the floor it would move on heavy bends. This table must weigh at least 400 lbs without the tools on it.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Feb 2008
    California
    51
    looks cool.
    i was wondering the same thing about it moving
    Nov 2007
    Bosque Farms, NM
    10
    Default hole augers
    Im buiding a picket fence ,need to auger out 35 holes 2ft.deep X 4" dia..Rental is ok,,,but I rather have my own,,any suggestions on a good 2 person auger to buy .thanks ............
    Raymore Missouri
    1,906
    Unless you're planning to do larger work also............
    I have a 1 man Earthquake turning a 8" auger. It has a two stroke engine which starts easily, is lightweight, and doesn't cost an arm and a leg. I think Home Depot has them. I like mine. Check them out. They also have larger Earthquake models also.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
    Nov 2007
    Shattuck, OK
    84
    Looks good. I also was wondering about it moving and also how you got the plate welded solid to the brake drum. We tried doing that at work for a stand we built and finally gave up and bolted it to the drum cause we couldn't get a solid bead on it. Just wonderin if there is some special technique to it. Otherwise, nice bender and stand and be sure to show us what you make with it!
    At Home
    Miller Thunderbolt XL AC/DC
    Performance Tools 6" Bench Grinder
    Craftsman Hand Tools
    Craftsman Cordless Drills
    DeWalt Angle Grinder
    1976 AMC Jeep CJ7
    1980 Ford F150 Custom
    1994 Chevrolet Silverado C1500
    At Work
    Miller Bobcat 250
    2 Miller MM251s
    2 Miller MM252s
    Miller Dialarc 250 AC/DC
    Lincoln Idealarc 250 AC/DC
    Snap-On Flux Core Welding Machine
    Hypertherm Plasma Cutter
    Victor Torches
    2006 Chevrolet Silverado 2500HD 4x4
    Proud American Ham KE5TJA
    Dec 2005
    Dallas, TX area
    267
    Default moving, et al
    Quote Originally Posted by bryce_burden View Post
    ...how you got the plate welded solid to the brake drum.
    I haven't used it yet. However, if I have a problem with it moving, I plan to overbore holes in the floor and cement 1/2" nipples in them. Then weld ears made of angle onto the base and secure the whole shootin' match with cinch pins. Thats what I be thinkin'.
    I will shoot some pics of my beads tomorrow. I welded the plate to the brake drum with my Maxstar 150STL, DCEP, 1/8" 6010 5P+, ~95A.
    HTH
    Triggerman
    CST-250
    Jan 2008
    haslet, TEXAS
    109
    Well how many Tigrs' you got thought i saw two in the back ground, or maybe all those flashes are makeing me see double!!
    me thinks the 2nd one is a spectrun 375 extream maybe....just a guess though.
