Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: union advice
    Dec 2011
    Default union advice
    I am a student of the Tulsa Welding School due to graduate in January. I am looking to get into a union by the time i start my career. Thing is I have been searching and dont know where to look. Maybe I could use a list of welders unions or something. Im in Oklahoma for now but really would not like to stay here. Any recomendation on where to look or go to talk to someone would be great. I want to work manufacturing or construction with minimal traveling. My first choice is TIG welding but am open to other processes. I have about 7 weeks till i graduate I hope i can get the advice and research done by then. Thanks in advance for any help you provide.
    Jan 2011
    21
    Look for a Pipe fitter/welder union in the area or an Ironworkers union. Those are usually the best choice for steady work with minimal travel. Also there is Boilermakers but they usually do a lot of travelling.
    Mar 2010
    Ceres, California
    351
    Don't just try to go through the union hall for a job. Check with any place the does welding. You may be able to get a job and they will help you get into the union they use.
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
    Dec 2011
    ok that may help now i know to look for pipe fitters or ironworkers union. my searches for welders unions were not bringing up any just other people asking the same question i had. i dont plan to let the union get me a job im gonna try through the school but so far havent been able to get any straight answeres from them about any of their job opportunities being union. they may not even know. is that something that i should ask in an interview? and if they are not a union shop would it make them mad if i ask and want to be in one?
    I don't know the referral procedures for the boilermakers, fitters, or ironworkers but I have been an IBEW electrician for 23 years. Generally speaking, you get your jobs through the union hall. Unless the shop is going to sponsor you and get you into the apprenticeship program, if you hire out as a mechanic it will be through the hall.
    Cool Unions are a great thing.
    I would call your local unions halls, pipe fitter and plumbers are part of the UA.org you can get local phone numbers from there. Most unions teach more then welding. Most people will tell you welding is only part of what your doing don't get me wrong there is a high a skill involved. But a person can only weld and not fit pipe or read plans has a big disadvantage over someone that can do all 3. But starting your apprenticeship knowing how to welding and building on that put you ahead of most. Remember one the thing welding in school and welding in the field are to different animals. There nothing like laying on your back in the snow in a trench welding a hot water main. Good times lol
    Illinois
    459
    hi, try CHICAGO ILLINOIS Pipefitters LOCAL 597. They did have a welding hybred program from what i was told. Not sure on how it is set up but could be a start. I think if you enter the program you get a jump on the apprenticeship. I believe its credit toward the apprentice program .
    as far as travel, that could be a problem. If you want to work you may have to travel or move where the work is. Good luck, bob
    http://www.pf597.org/
    what type of work are you most interested in?
    Mar 2011
    Sykesville, PA
    126
    I just started as an apprentice with the sheet metal workers. There is quite a bit of welding. But like you i started looking for a welding union and found nothing. The plumbers and pipe fitters does alot of welding, but like said there is alot of other things to know. They do more than just welded pipe. Same with the iron workers. There is alot of welding but its not all welding. Boilermakers probably do the most welding but you travel alot. As for the traveling it depends on where you want to live. If you want to live in a rural area your going to travel with a union. If you live in a city or suburbs not so much.
    Linclon power mig 350MP
    Mar 2009
    Michigan
    137
    Default Why Union?
    I graduated with an associate in applied science – welding technology in 2008. And I have been working in non union shops since then making decent money working as much as I want; I do mostly TIG on SS. I am very happy with my job, and wondering what would a union do for me or why I would even want to be a part of one? Maybe the OP should consider non union also? Granted I did find a very honest shop with high morals and ethics, and they treat us excellent and with respect. The reason for Union is to protect the workers. The workers pay a fee to be protected. If you don’t Need to be protected, then why pay the fee? If we had a union in our shop I would be paying them money and they wouldn’t have to do anything, because we are Happy!
    Miller Syncrowave 200
    Miller Spectrum 875 Plasma Cutter
    Miller Milermatic 135
    Ridgid Drill Press
    Ridgid Chop Saw
    36" Metal Break
    Harris Toarches
    English Wheel
    Ingersoll Rand, 18.1 cfm Compressor
    30 gal. Sand Blaster
    Planishing Hammer
    150lb Anvil
    10" Swing Logan Lathe
Tags for this Thread
