I am building a 6 sign billboard, but the customer wants to use a 3/16 wall steel pipe. My engineer can't find any structural specs on the pipe, 4" 5" and 6", it doesn't matter if that is OD or ID. He needs these to figure the windload, the moment, or breaking point. Any info is a plus. I have searched myself and come up empty, even calling our local and some out of town supply yards. Hoping someone on here can help point me in the right direction. Thanks.
Thread: pipe specs., info please
11-30-2011, 07:15 AM #1
DAY WELDING LLc
1992 dodge cummins welding truck
trailblazer 302
2004 cummins welding truck.
old SA 200
Victor torch set
Lots of crazy ideas!!
11-30-2011, 01:04 PM #2
- Feb 2004
- 1,160
That really doesn't sound right, any engineer doing structural calcs will have that information at hand.
I'd look for another engineer if it was my money.
I don't think there is a structural engineer on the planet who doesn't have the
AISC Steel Construction Manual, a small book that list's properties of every structural shape in common use.
It's also really good for detailing information to those of us who aren't engineers.
JTMcCSome days you eat the bear. And some days the bear eats you.
12-02-2011, 09:00 AM #3
- Aug 2006
- Plainview, TX
- 334
Schedule 40 Pipe Specs are easy to Find...
However, 3/16" wall thickness in 4", 5" or 6" is tubing or RIGID CONDUIT wall thickness and IS NOT STRUCTURAL. 4" Sch. 40 Pipe has a 1/4" wall thickness and is plenty stout. Sch. 40 data is available on the internet and in any Enigineering Handbook in Publication. Sch. 40 is also listed in anything that has Structual Materials or elements listed. Get a copy of Shapebook 2009, it has all the structural design details for structural steel listed. Then of course, you could find a Structure of Materials Textbook from a University Bookstore and calculate the things you need to know by hand.
I would not use 3/16" wall tubing for signage, unless proper reinforcement could be designed into the engineered piece.'77 Miller Bluestar 2E on current service truck
'99 Miller Bobcat 225NT for New Service Truck
'85 Millermatic 200 in Shop
'72 Marquete 295 AC cracker box in Shop
'07 Hypertherm Powermax 1000 G3 Plasma Cutter in Shop
Miller Elite and Digital Elite Hoods
12-02-2011, 10:16 AM #4
- Feb 2004
- 1,160
.188 wall is common in Line Pipe, in sizes quite a bit bigger than 6".
If they spec that wall thickness then I'd guess they had bought surplus pipe at a good price and want to use it.
12-02-2011, 01:41 PM #5
Just checked my two CISC handbooks, and I cant find specs for your steel pipe you have chosen. I agree with flukecej, you could try using some round HSS steel instead.
LukeLincoln tombstone AC/DC
Hitachi Chop saw
Victor HEAVY Duty Torch set (propane)
ATLAS Model 618 Steel lathe
Hitachi Grinders
Lot of hand tool and hammers
150LB Anvil+ a forge
Lincoln SA 200
12-04-2011, 05:17 PM #6
- Sep 2005
- 4,247
A good way to get a quick idea may be to look at other units that have been engineered, do they do them the same way?
