Brian
here is an article on welding automotive aluminum cylinder heads... there is a lot of similarity between the two..
http://www.enginebuildermag.com/Arti...num_heads.aspx
best of luck and please keep us posted...
Results 11 to 15 of 15
Thread: Aluminum Intake Manifold
12-12-2011, 09:04 AM #11
- Nov 2003
- 2,019
The more you know, The better you know, How little you know............................. (Old Estonian Saying)
01-04-2012, 05:52 AM #12
Member
- Mar 2011
- 69
I've managed to get the extension welded onto the old intake, went pretty well. No leaks on a 40psi pressure test. I guess we'll see how it holds up.
01-04-2012, 10:02 AM #13
- Nov 2003
- 2,019
That is Great!!
could you outline what you did to accomplish this with limited amperage??... preheat.. blankets etc....
Thanks...
01-04-2012, 01:17 PM #14
Member
- Mar 2011
- 69
I preheated on my gas grill (don't tell the wife) before making the welds where the new material attached to the casting but I didn't get too crazy the thing may have been 200deg or so. I didn't maintain any heat on it while I was welding other than what the welder was putting in.
The areas I was attaching to were about 1/4" thick with the new material being 1/8" and 1/4" the only places that were thicker where were the old bolt bosses were.
Had the Sycrowave 180 set at about 165a and luckily didn't have any problems except for a couple of really tight inside corners where the arc was jumping all over the place....fortunately where that was happening I was able to get nice clean welds on the opposite side of the joint so no problems.
01-04-2012, 01:50 PM #15
- Nov 2003
- 2,019
Brian
thanks!! that will give the guys with smaller machines some food for thought before they tackle aluminum castings...
Frankly... I was concerned about your outcome.... glad you thought your way around the situation.....
