Results 1 to 10 of 11
    Nov 2011
    5
    Default Help needed for AirCo Welder/generator w/ Kohler Engine
    We purchased an AirCo welder/generator with a Kohler Engine. We are looking for manuals and parts to include consumables. Pictures can be provided if neccessary. All data plate information that is legible is listed below. Any information you can provide is greatly appreciated. Thank you.
    AirCo Ser# M2755830
    Kohler Engine Model K331
    Kohler Engine Serial Number &50073
    Kohler Engine Spec# 38131D
    6,752
    Need the welder spec # off the unit, All the rest you supplied means nothing...
    Pics?
    Nov 2011
    5
    Default Locating Spec number
    After a through search of the unit we could only find two numbers. The first is stamped on the outer casing of the unit. That number is M275830. I assume that it is a serial number, however only the number is stamped (see attached photo). The second number was found inside the unit with a date. It reads; 4MO7, Aug 63.(also see attached photos). Is there a specific area that the spec number is usually found? Any additional information you could provide is greatly appreciated. Thank you.
    Nov 2011
    5
    Default Attached pics
    I have attached pictures. Thank you!
    6,752
    Hmmmm, GREAT pictures, though where is the FRONT pic, you know, the pic that we really need.....
    Nov 2011
    5
    Default Pics
    Nov 2011
    5
    Default More Pics
    Thank You!
    Jan 2012
    Ontario,Canada
    3
    hey just seen your post I have a MEMCO BANTAM and it looks the same as yours.. The one plug has been swapped for a twist and lock.. I just got mine and haven't been able to find K331 Parts yet.. PM me your email and I will send you a K331 Parts manual and the Memco Bantam Owners Manual
    Jan 2012
    Ontario,Canada
    3
Tags for this Thread
