Like what you did. I might follow.Originally Posted by Steve83:297489
Results 11 to 20 of 21
Thread: 211 millermatic issues
12-08-2012, 03:03 PM #11
Miller Bobcat 225NT onan
Millermatic 211
Spoolmate 100
Miller 130xp
2. 4-1/2" grinders
1. 9" grinder
14" Makita chop saw
1/2" Aircat impact gun 900#
12-11-2012, 10:34 AM #12
I used a Brother P-Touch with white-on-clear ES adhesive to add "ON - OFF" labels beside the switch in a font similar to the welder's original, so now it almost looks factory.
Walk softly & carry a BIG SIX ! ! !
MM211 + SM100
12-11-2012, 12:13 PM #13
Member
- Jul 2012
- 84
Thanks Steve83. I'll be moving that switch this weekend too. It's annoying back there.
And you are correct. The sensing components for the spool gun would cost less that the switch gear.==============
Miller 211 MVP
Hobart StickMate LX 235
Lincoln AC 225
CutMaster 42
12-11-2012, 04:35 PM #14
Your welcome to do what ever you want to, however, if it was still on warranty, it isn't now.....
12-12-2012, 03:19 PM #15
- Apr 2011
- 306
Cruzer...
Are you guessing or have experience...?
I would think that the warranty issue would have to be proven to be a result of adding/moving the switch...?
kind of like the whole adding a tuner to your diesel truck blah, blah, blah, out there which isn't true.
Not looking for a war, just a clarification, I trust your judgment.
(Edit: PS sorry to second guess you)MillerMatic 211 Auto-set w/MVP
Just For Home Projects.
12-12-2012, 04:02 PM #16
Unless you got the ok in writing from Miller, doing ANYTHING inside the machine will nullify your warranty. I'm a Miller CST tech, and I know what you can and can not do.
12-12-2012, 06:52 PM #17
Warranty
Well, it's disappointing to hear that from a Miller CST. I'm a professional, too, and I've never voided a customer's warranty on one issue because he did something UNRELATED to another part.
But since I don't plan to put this machine anywhere NEAR its limits, I don't plan on using the warranty; not that I think my local dealer would even accept it for warranty without the mod since I didn't buy it from him. If something goes out, and Miller won't direct-ship me a replacement part, I'll buy one and install it myself.
I wonder how long it'll be before Miller moves the switch to the front, and if they do, will mine go back INTO warranty?
While we're on the subject, and we have a knowledgeable CST participating... Whom should I contact to get that OK in writing? It should be easier now that there's a photo showing how well the wiring was modified & repaired, right?Last edited by Steve83; 12-12-2012 at 06:54 PM.
MM211 + SM100
12-13-2012, 07:59 PM #18
12-14-2012, 08:46 AM #19
Member
- Nov 2010
- Oregon
- 41
**** you, why didn't I think of this mod, now I'm going to have to steal your idea!
On my 211 I have the factory Miller cart that goes with it and had to slide a piece of 1/2" plywood behind the machine and the cart to get to the switch and its still a PITA.
Good job!
DannoMiller 350 LX Tigrunner
Miller 350P w/XR-Pro
Miller 250MP w/30A spool
Miller 211 Autoset
Hobart Tigwave 250
Hobart Beta-Mig 251
12-14-2012, 04:32 PM #20
- Oct 2006
- Illinois
- 459
Sounds like YOU just gave MILLER the idea on the switch location. It will be interesting to see if they do it. Great location for it.
