It is impossible to selectively anneal tubing of that size. The best bet to bend it in T0 (dead soft annealed), then if mechanical properties are needed above that, solution heat treat and age for T6.
How would I do this? Make a round bending jig from 1" MDF, using a router bit and pivot arm to precisely route a semicircular channel all around. Route two flat pieces of MDF with channel to grip, then attach both to the bench and go to town. It is best to pivot the jig and fix the flats to the bench, using a lever to pivot the jig
I had to bend several coils from 0.035" wall, 1/4" stainless tube and built a jig like this. Only used a drill press to spin the coils. Nice and tight.
Results 11 to 12 of 12
Thread: Best aluminum alloy for bending?
11-19-2011, 06:39 PM #11
- Jul 2011
- 162
11-20-2011, 08:10 AM #12
- Jul 2008
- East Tennessee
- 609
If you want to do this yourself and not out source this is the simplest solution.You will end up with a decent tubing roll for the money as well. I took this advice from Sundown about a year ago on a stainless boat bow rail project and it worked great.Keep us posted on your progress.
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1982 Lincoln sa200
