Thread: Pass Port Plus
    Jun 2007
    Reno, Nevada
    31
    Default Pass Port Plus
    Picked up the Pass Port Plus last week. This week I want to get the spool gun for it. What all do I need to run aluminum on the Pass Port Plus? Spool gun, gas and wire? What type of gas for the aluminum?
    Thanks....
    Appleton, WI
    424
    ProWorkz,
    Congrats on the new machine The Passport is great little unit and really packs alot of punch for it's size. To set your machine up for aluminum you will need these items:
    Spoolmate 100
    1 lb spool(s) of aluminum wire
    A bottle of 100% Argon gas
    Regulator and gas hose for the Argon
    You may want to get some extra contact tips also.
    Kevin
    Jun 2007
    Reno, Nevada
    31
    Default Spool gun
    Kevin thanks for the reply. I picked up the spool gun two weeks ago. I plan on running my first aluminum beeds this week with the spool gun. What is a good flow rate for the Argon? Thanks.....
    Dave
    Glen N.Y.
    902
    ProWork,
    Last week I got my 5th PassPort + and they all weld just about the same.
    When you startout with the PassPort + you'll need to start on the low side of the rrecommended settings. The little PassPort + has alot of power and I find the factory settings are kinda high. Also, when you adjust the machine, I have found that the adjustment knobs are VERY sensative. Each little click makes a big difference.
    Good luck,
    Bulldog
    5 Passport Pluses
    2 MM 212's
    MM 210
    MM 251 MIA
    MM 350 P w/Python
    w/ tig runner
    Trailblazer 302
    12RC w/meters
    Spectrum 1000
    Spectrum 2050
    2 Black BWEs
    Joker BWE
    Star & stripe BWE Digital
    2 star & stripe xlix's
    REAL TRUCKS RATTLE
    CUMMINS BABY
    Appleton, WI
    424
    Pro,
    20 to 25 CFH should be all you need.
    Kevin
