    Nov 2011
    Default welding aluminum overhead
    I've been having difficulty trying to keep the arc on the upper ( horizontal ) member , any help would-be appreciated. This is on a semi trailer
    Jul 2008
    Flin Flon & Creighton area
    233
    Default what process? mig tig?
    Hello, we need more info to give informed advice. If your using MIG your gun angles and how clean the base metal could be a place to start. Are you pushing or dragging your puddle ? What shielding gas are you using? How thick of base metal are you trying to weld. I assume your welding a lap joint or a inside corner ? all of these variables will have an effect on how good of a job you will be able to do.
    I have a welding addiction
    8,231
    Quote Originally Posted by GarySS View Post
    As with the above note, what equipment are you using for this task??
    Maybe a spoogun, as its very unlikely your going to do it with a mig gun, and if your attempting to do overhead with an Aluminum stick, just forget about it.
    3,949
    Thats the one thing all of the welding vids that show how to weld alum don't show. They all show nice flat welds and how easy it is. Now you have a non textbook weld. If with mig and you have cleaned the alum and have enough heat to do the weld. I hold my gun just like welding in the flat at a 45 to the corner and tipped back about 10 degrees then i make little circles to keep everything flowing. Just my thought and how i do it yours may vary...Bob
