I've found craigslist to be a good source of low cost beam trolleys and hoists
Results 11 to 20 of 20
Thread: chain hoist A-frame help
11-16-2011, 08:23 AM #11
- Sep 2005
- Warren PA
- 103
11-16-2011, 11:17 AM #12
- Apr 2011
- 315
Jet
Just For Home Projects.
11-16-2011, 05:40 PM #13
Member
- Oct 2011
- 38
I'll probaby just end up making a trolley, those suckers are pricey!
11-16-2011, 05:43 PM #14
- Sep 2005
- 4,248
The manual 2 ton from Jet is 129$, if someone gives you the materials and your time is worth about a dollar an hour it would be practical to make one.
11-16-2011, 05:47 PM #15
Member
- Oct 2011
- 38
I can get the materials pretty easily, and time isn't really an issue, it would be better than spending a hundred bucks, and give me a little project to work on
11-21-2011, 11:17 AM #16
- Apr 2011
- 315
Trust...
...I would trust their engineering and material spec's long before your's...no offense.
11-22-2011, 03:52 PM #17
- Sep 2010
- 10
Hope the hoist design is coming along OK. We use google sketchup a lot to help work out designs - it's free to download and, as 3d design packages go, it's pretty easy to learn. Here's a link to the sketchup site http://sketchup.google.com/. Might be fun to try out a few alternative hoist layouts in sketchup.
11-23-2011, 06:15 PM #18
Sure, very easy to make.
I needed to lift my boat engine (4 cylinder Johnson) off my boat and the only way to do it was with a lift.
I hung a 2Ton hoist off the frame I made at home.
Then I had to load the hoist into the bed of my pickup and drive 60 miles south to where the boat is stored on the Gulf Coast.
Here is the frame as I was building it.
I used a 4 inch X 4 inch H beam across the top, and put a wheel on each corner.
The frame has no more bracing than you see in the pic and is wide enough for me to drive under it when assembled......
Is it portable?
You be the judge of that.......
I got it down there and back and the engine came off the transom easily. So I have to say it is portable, but I need to take a ladder with me as it is 11 feet tall..
pg
Dynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
11-27-2011, 09:39 AM #19
That looks like a great design. My only concern would be the 4X4 H beam. How much does it weigh and is is hard for one person to place it?
Thanks,
Nick
11-27-2011, 11:31 AM #20
Nick,
I used a W4x13 beam and it is 8 ft long. So 8 x 13 = 104 lbs.
I made two of these.
One I keep at the boat shed and it is standing erect over the boat.
The other one is at home (broken down) and stored in the garage.
The first one I did went to the boat shed.
I erected it by myself.
The shed has a 12 ft ceiling so I screwed in a hook to a joist and raised the beam with a chain hoist. Then bolted the upright legs on..........
The one at home I have no high ceiling to use so I simply bolted one upright leg to the beam on the ground.
I next picked up the other end of the beam and climbed up a ladder holding the beam in my hand.
The end of the beam was then placed on top of a second ladder.
I went down and grabbed a wrench and the 4 remaining bolts and attached that end to the other upright leg.
The tail end of a 104 lb beam is not that heavy.
I weigh 160 lbs and stand only 5'-6" tall, so if I can do this anyone can. I was working alone with no help at all in both cases.
This one came apart the same way when it was time to store it.
pg
Coolmate 3
Victor O/A Rig
