Results 1 to 10 of 20
    Default chain hoist A-frame help
    I just ordered a 2 ton chain hoist for lifting heavy things out of the back of my truck, I have some strong tree branches to hook it to but I wanted to build something for it instead, something I can back my truck under, so I can place whatever it is I'm lifting where I want it, I was also thinking about making it collapsable so I can take it with me to load and unload things, maybe a pin or bolt can hold some pieces together so it can be taken down easily and transported, here is a terrible sketch i drew on my Android phone, any help or comments are much appreciated!
    WY...armpit of U.S.A.
    659
    Should give you plenty to look over...
    http://www.google.com/search?um=1&hl...st&btnG=Search
    Miller DialArc 250
    Lincoln PrecisionTig 275
    Hypertherm 900 plasma cutter
    Jet 14 X 40 lathe...ditto
    Logan 7" shaper
    Ellis 3000 band saw
    Lots of dust bunnies
    Warren PA
    103
    they are easy to build, but don't expect it to be easily portable. the one I built is technically portable, but its more than a one man job, ****, just adjusting the height is an ordeal.
    Nov 2009
    South Alabama
    257
    I built one with reciever tubes on each end of the I beam so I can break it down and store it out of the way, can't find any pictures of it right now or I would attach them.
    "The only source of knowledge is experience." Albert Einstein
    Jul 2011
    162
    2 tons? Wide enough to lift a 2-ton item out of your truck? The limiting factor here is the beam spanning the two sides.
    A 100 inch (8 foot, 4 inch) span of wide flange W6-9 (like an I-beam but more stable) will take that load with about 3/16" deflection and peak stress of 18,000 PSI. For ASTM A36 material, this gives a factor of safety of 2 against yield (ASTM A36 material in this section has a minimum yield stress of 36,000 PSI).
    This material weighs 9 pounds per foot. That span is a good 75 pounds without the chain hoist.
    Now for the A-frame design. Instead of an A, make it a complete triangle. Use the same material. Width is all dependent on height. Diagonal gussets at the cross beam to triangle intersection is also a good idea. For a quick take-down, the design becomes more complex.
    4,456
    I have loaded mine about as much as I wanted to, ha, as I recall we measured it. I had a cobbled up beam and found another one. I raised and spread legs a little, will roll thru 14 door. I like it because although it has a home it can be moved around shop.
    Thanks for all the help guys, I have a much better idea of what I'm gonna be building now
    4,456
    I re-did mine a couple of times over the years. Made the wheels from pipe. When I upgraded the beam it was about 20 ft and I cut it to 18, made it a bit stronger and the fit in the building worked out as good as it could, give enough width that could remove something from a truck and carriage it sideways, set on floor, is wide enough that projects sitting under it that doesnt cause crowding.
    I had 2 beams, used one I should have used another for and had intended on building a different unit that mounted to building post on one end, this I had already and was portable, I really didnt need 2, its liveable in the way and works.
    I built a small one for a Bud, post at wall is for load but hinges on it, the close leg arcs and rotates.
    Where do I find those rollers that hook to the I beam? Or how can I make one?
    northern NJ
    1,907
    Do a search on the web for "I-beam trolly".
    MM250
    RCCS-14
