Results 11 to 13 of 13
Thread: Engine Block
    Nov 2008
    27
    Quote Originally Posted by CSTKmauro View Post
    I have used a flame spray torch made by ESAB which is the only way I would repair cast iron. For more details on how it works you could go online and look it up. But I have had a lot of success with it. Basically it's a oxygen and acetylene torch with a built in hoper and when depress the trigger you start spraying metal which has the same properties has the cast iron base metal so it will cool at the same rate so you don't get any crakes. Its truly awesome. I know my company stocks them at www.airweld.net but you can find them all over. Good luck.
    Wow, those things or over $3K.. Ouch. Looks just like a reg oxy/acet with a hopper.
    3,647
    Quote Originally Posted by mikeb9550 View Post
    I sold a brand new one for 200...Bob
    I believe a seemingly primal approach to this issue will suffice, I was told by a welding consultant that when working with a cast iron engine block, any rod cast metal may be used (after being heated to roughly 250°) then dipped into a granular flux, once cooled and used as a typical filler rod in the Oxy-fuel process.as far as I understood from the lecture...the preheating of both pieces is crucial for complete fusion.
    Hope this is helpful!
