Page 6 of 12 FirstFirst 1234567891011 ... LastLast
Results 51 to 60 of 113
  1. #51
    Sep 2008
    13
    Default Some of my stuff
    Here is some of my stuff.
  2. #52
    2,967
    Quote Originally Posted by curly View Post
    That actually may just be a nut welded onto the thing...but I'd still like to know (tap and die or something)
    Yup-Tap & Die set
    They can get pricey so welding a nut on is cheaper fer sure.
    Sometimes you have to anyway iffin' the material is not thick enough to provide enough meat for threads.
  3. #53
    Sep 2008
    Union SC
    78
    Yup-Tap & Die set
    So, do you find your self using them much/ever (tap and die), or usually weld the nut on?
    Millermatic 212
    1998 Heritage Springer
    Kioti DK55
  4. #54
    Mpls, MN
    1,790
    Anybody wanna tell me how to get the threaded hole in this. Some kinda tap thing I believe but I've never done that so don't know. Anyplace to get one reasonably priced, like harbor freight or NT? What are they called?
    Tap's cut threads on the inside of holes, dies cut threads on the outside of shafts.
    A decent tap and die set (typically 4-40 through 1/2") will run you a couple hundred bucks. Don't waste your money on the HF/NT garbage. These are extremely handy and worth getting a good set (HSS, not carbon steel!), as the cheap crap that breaks in the hole will cost you more than the good ones when it comes to EDM the busted one out of a valuable part.
    I would never use a die to cut threads on a shaft if I had another option (often its faster and you get better threads to just cut the head off a bolt), but they do become invaluable in salvaging damaged threads.
    If you don't want to plunk down the cash on a full set up front, ebay has at least one outfit that offers regrinds for cheap. The other option is to keep an eye on local machinery auctions and maybe you'll get lucky like I did. I spent $150 on a Huot 4 drawer master tap index chock full of darn near everything I would ever want, and a whole bunch more I'll probably never need. The cabinet was worth $100 - the taps are probably worth over a grand.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
  5. #55
    2,967
    Both.
    Rough stuff I'll weld a nut on.
    But on say a Finished piece like the Would Rack you wanna make, a Tap wood be used
  6. #56
    Jan 2008
    east central il
    23
    Default my project
    Quote Originally Posted by Gsd34me View Post
    Please show your pics of some small projects for us board members to get some good ideas. Thanks all!
  7. #57
    Feb 2008
    11
    Quote Originally Posted by retiredIW View Post
    Now this one is really cool.Does it have a door somewhere that locks?
  8. #58
    Sep 2008
    Union SC
    78
    Both.
    Hey, I resemble that remark
    Millermatic 212
    Kioti DK55
  9. #59
    Sep 2008
    Omaha, NE
    447
    Here's a few of mine, nothing major, and i'm waiting on the starter cart to come back from powder coat so i can get "finished pics" of it. (edit..can't find the cart pics, but the plate to hold the starter and start the bike is in here)
    here's the pics (if i get the upload right hehe)
    I need to find what hard-drive and folder i have the rest of my stuff in. These are some of my first projects with the new dynasty that were small and just playing around making things for myself (except the starter plate for the drag bike) Teh fuel rails are just some import car rails that were fitted with -6 AN fittings for upgraded fuel systems for E85 swaps
    I'll post the new better projects as soon as i find them
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
  10. #60
    Apr 2006
    Mission Hills, CA
    48
    now thats a mail box more to my likein..... hmm
