It does me to, but I have the bride in the other room that will bail me out.
Rob
__________________
"There are questions to be answered, and answers to be questioned"
Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
http://www.1969supersport.com
Results 31 to 40 of 113
02-16-2008, 03:21 PM #31
- Dec 2007
- two rivers wi.
- 23
02-16-2008, 03:27 PM #32
- Dec 2007
- two rivers wi.
- 23
Go ahead and put your pictures on, I would like to see what your doing.
Rob
__________________
02-16-2008, 08:32 PM #33
will do Rob.
I'm up against a mountain and a 1/2 with these floor pans, as I said I have not started on them Primarily cos of no time as of yet but also cos I use the chevelle Regularly.
when I start on it tho it'll be down for awhile. someone welded sheets of metal on top of the actuall Rotting floorpans. so I not only hafta cut thru that, but the floor pans themselfs, A real nightmare under there
traded the MM180 in for a MM212
lots room here for more machines like, a Plasma cutter oooohh yeah!
tinkerer with many talents,master of none
02-16-2008, 09:41 PM #34
- Jan 2008
- VA
- 298
2 post to 4 post adaptors.
I made a set of adaptors so my cars can be stored on my 2 post service. Normally the wheels hang and you have to place the lifting arms before lifting the car. With the adaptors you can drive right on and off.
02-16-2008, 11:39 PM #35
- Dec 2007
- two rivers wi.
- 23
That is pretty slick.
Rob
__________________
02-17-2008, 04:56 AM #36
Vicegrip.........do the bolts have a head on them and come up from the bottom?
Miller 252 Mig
Miller Cricket XL
Millermatic 150 Mig
Miller Syncrowave 200 Tig
2-O/A outfits
Jet Lathe and Mill
Jet 7x12 horz/vert band saw
DeWalt Multi Cutter metal saw
Century 50 Amp Plasma Cutter
Propane Forge
60" X 60" router/plasma table
02-17-2008, 06:09 AM #37
- Jan 2008
- VA
- 298
Yes they are 1.25 grade 8 150,000 psi each. The heads are shouldered in the box, welded to the box at the head and on the shank, welded to the angle that runs under the box and also welded to the 1/4 top plate. The top plate is also welded to the 1/4 angle to reinforce the rectangular tubing in the bolt area. I use this to lift race cars that are in the 2000 pound range. I would use much heaver stock if i were to build for heaver cars. As it is I purchased the bolts and then used "found" stock (AKA scrap or leftovers) I had on hand after the idea came to me one afternoon.
02-17-2008, 10:45 AM #38
Here you go....
Here are pics of my last two projects:
Triggerman
Ammonia refrigeration tech
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
02-17-2008, 10:52 AM #39
New aluminum Kite Buggy made out of 1.5x1.5x.125 and 2x2x.250 5086 square pipe. Can't wait to finish it
I made an arm for my flat screen lcd tv . Now it looks like it is floating in air. It swivels away from wall and pivots so you see it anywhere in the room.
and for giggles empty and weld beer cans together and to a 1/16 5086 plate( I do it cause I" CAN!"
02-17-2008, 11:26 AM #40
hey triggerman!
the first pic is a tube bender init? if so have ya bent any exhaust pipe on it?
is it hard as ****?
I wanted to get one but thought, that has got to be a motherhead to get right,
bending pipes to go over the Rear axle tubes and all. can that tool make them bends on 2-1/2 dia pipe?traded the MM180 in for a MM212
