Page 2 of 12 FirstFirst 1234567 ... LastLast
Results 11 to 20 of 113
    The last 4 for now..
    Used some 2" and 2.5" 3/16 wall square tubing to make some brackets for mounting a removable bench grinder and vice on the end of my welding table into a receiver style setup.
    1 is the mount for the grinder
    2 is the receiver portion with hole for the retention pin and 2- bolts in tapped holes that when tightened take the slop out of the system.
    3 grinder all set up
    4 grinder and vice stored out of the way so that the entire welding table is open.
    Thanks for looking
    Mark
    two rivers wi.
    23
    Quote Originally Posted by badassb5 View Post
    WOW I looked at the chevelle pics. Amazing work, I mean world class. Very nice.
    Thank you for the nice compliment.
    Rob
    two rivers wi.
    23
    Heres some more goodies.
    http://www.1969supersport.com/jigs.html
    Rob
    __________________
    "There are questions to be answered, and answers to be questioned"
    Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything.
    two rivers wi.
    23
    This will double the life of a disc, ( almost )
    http://www.1969supersport.com/tls.html
    Rob
    __________________
    two rivers wi.
    23
    Yeah, I know i have way to much time on my hands, but it keeps me out of the tavern.
    http://www.1969supersport.com/dog1.html
    Rob
    __________________
    Montana, USA
    232
    Quote Originally Posted by rubadub View Post
    Heres one for you guys, its to do with ventilation in your shop or garage to get welding fumes out.
    I use it it for welding fumes, plus my home made paint booth.
    Anyway the vents are insulated, because i live in Wi. But I also use an air conditioner once in a while in the summer.
    This is on the first five pages of this,http://www.1969supersport.com/paintroom.html the pictures are scattered around a little, but you can see the insulated vents. Anyway, for whats it worth.
    Rob
    __________________
    Wow! Obviously, you do not suffer from ADD, like some of us. Am very envious of your organizational skills, and sure do appreciate that you took the time to document and post some of your accomplishments. Nice work!
    Goodhand
    __________________
    http://www.1969supersport.com[/QUOTE]
    Mpls, MN
    1,790
    Rob, and everyone else...
    Rather than using angle bolted to the ceiling, you should use electrical strut instead.
    This stuff is super strong, and comes with slots for easy installation on standard spaced studs. HD has it in stock for about 13 bucks for a 10'er.
    The rolled edges are made for a plethora of standard brackets and nuts, but can also work to hook your wire hangers on as well.
    http://www.tnb.com/ps/pubint/index.cgi?a=get_sub&cid=9
    http://www.tnb.com/contractor/docs/superstrut.pdf
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
    May 2006
    180
    Here's a shot of the bandsaw cart I designed and tigged together to replace the backbreakingly low legs the saw came with from the manufacturer. It can be disassembled into three pieces (apart from the saw) for saw storage or transport. The casters are bolted on (not welded) for easy replacement.
    Miller XMT-350 CC/CV
    Miller S-22A wirefeeder
    Bernard 400A "Q" gun
    CK 210 & WP-18 GTAW torches
    Hypertherm Powermax 30
    two rivers wi.
    23
    [QUOTE=Goodhand;26163]Wow! Obviously, you do not suffer from ADD, like some of us. Am very envious of your organizational skills, and sure do appreciate that you took the time to document and post some of your accomplishments. Nice work!
    Goodhand
    Your welcome Goodhand
    Rob
    __________________
    two rivers wi.
    23
    Quote Originally Posted by Fishy Jim View Post
    Good idea, I never thought about using it.
    Rob
    __________________
