Page 10 of 12 FirstFirst ... 56789101112 LastLast
Results 91 to 100 of 113
  1. #91
    Default Spray foam?
    Quote Originally Posted by Rubiconmike View Post
    You can get you're tires filled with foam
    so they never go flat.
    The grips in the movies do that.
    Is that right?
    How you do that?
    can you do it with the spray foam in a can or you need special equipment?
  2. #92
    Columbia SC
    165
    Finished this "Happy Cat" for a woman today...
    Jim
  3. #93
    Sep 2008
    Omaha, NE
    447
    Quote Originally Posted by Sherweld View Post
    This was made from 100% scrap and recycled materials. Maybe I should have painted it green ...
    Thats one of the coolest little welding carts i've ever seen. very nice work!
    Hobart Handler 135
    Smith MB55A-510 O/A setup
    Lathe/Mill/Bandsaw
    Hypertherm Powermax 45
  4. #94
    Mar 2008
    148
    Just learning TIG...............
    RoyB
    Dartmouth, MA
    http://www.rvbprecision.com
    Millermatic 185 MIG
    Miller Diversion 165
    Purox W200 O/A
    Grizzly 9957 Mill
    Grizzly 4030 Metal Band Saw
    Grizzly 1050 Knife Belt Sander
    Jet 1236 Metal Lathe
    TP Blast Cabinet
  5. #95
    Oct 2008
    Den Haag
    22
    Here are a few of my latest:
    A spacer for stacking pie-plates in the fridge, folds for storage.
    A rough prototype Christmas tree holder. I'll clean this up and make it dissasemble after we are done with it.
    A Shelf for fitting a plant on a narrow window ledge:
    More (and larger) images, with explanations can be found on my Smugmug page here.
    Thanks for looking.
    Al...
  6. #96
    Clarksville, TN
    427
    for the tire foam stuff we got a two part stuff from john deere dealer took valve cores out tire. mixed up stuff poured through valve stem and let it do its thing after 20 minutes or so snipped the stuff that had squirted back out and had a solid tire. it was the caster wheels on the front of a large mower after the tires fell apart we were still able to run the foam rubber wheel for a few days.
  7. #97
    Dec 2008
    CDB Land, TN
    135
    Yard man
    Tractor
    Be safe
    Jeff
    Give more than you get and
    you will get more than ya need.
    This is true for the good and bad
    that life puts out.
  8. #98
    Apr 2005
    Saskatoon, Saskatchewan
    220
    Jewery box for my sister out of 0.080" aluminum, tig welding, polishing and glass bead blasting it.
    Thermal Arc 185TSW, Lincoln SP135+, 4-post automotive hoist, 2x media blast cabinets, 50 ton press, 80gal air compressor, 4-1/2"x6" bandsaw, 4'x4' Torchmate CNC table with plate marker, Hypertherm Powermax 65 plasma cutter, ultrasonic cleaning stations
  9. #99
    May 2008
    Austin Tx.
    101
    Default 30 to 40 pair shoe rack
    My father-inlaw asked me to make him an aluminum shoe rack for xmass.
    It is framed with 3/4" x 1/8" square tubing and the runners are 3/4x1/16" angle. I had a hard time trying to present it in photo's but here it is.
    Oh, btw, the cat is my biggest fan.
    Randall
  10. #100
    Jun 2007
    West Texas
    12
    Here's a fun little project.
    1Y Iron
    Millermatic 210
    Millermatic 135
    Miller Blue Star 145
    Spectrum 375
    Scotchman Porta-Fab 45
