Results 1 to 10 of 16
    Jul 2008
    Houston TX
    240
    Default Portable Band Saw Stand
    Last week I decided to buy a Makita portable band saw because I want to use it to cut out small brackets and tabs.
    For the past 30 years I have been using a hack saw and finally got sick of that!
    Of course you are not going to safely cut a small bracket out while holding the band saw in your hand, so a stand was needed.
    I just cut some 1-1/2 inch box tubing and used 1-1/2 inch channel for the base.
    The Makita has two threaded holes in the top of it and I used these to secure the saw to the frame.
    A small tab on the right sticks out and the saw body sits on that.
    I also made a larger table for the saw to replace the tiny sliver of metal that came with it.........
    The saw is rock solid. All I have to do is grab the handle and carry it where ever I need to go.
    pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    Victor O/A Rig
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    West Farmington, OH
    746
    Looks great!!! As long as it gets things done without getting hurt is the main thing. I could probably use that from time to time, I'm getting tired of the hacksaw at home as well. I have use of some vertical band saws but they're all big and not too good for small stuff. The other nice thing about that set up is it takes up a small footprint and can easily be stored under the work table when you're not using it. Also it looks like it can be detached quickly enough for when you need to cut long pieces or structural stuff.
    Like they say necessity is the mother of invention. Good job!!!
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    Jul 2011
    Tampa FL USA 33617
    17
    Can you post more photo's...I have been thinking of doing the same thing...thanxs
    Jul 2008
    Houston TX
    240
    Quote Originally Posted by Corbinworks View Post
    I will be glad to do that.
    I am trying to load a video of the stand on You Tube right now, and as soon as it is done I will post it.
    Thought a video will show more detail than a few pics.
    pg
    Coolmate 3
    Victor O/A Rig
    Jul 2008
    Houston TX
    240
    Corbin,
    Here is the greater detail of the portable band saw stand you asked for.
    Hope it helps you make yours.........
    http://www.youtube.com/watch?feature...&v=zEcrMNCLDLY
    pg
    Coolmate 3
    Victor O/A Rig
    Upstate SC
    143
    Good job. I'm going to get the same saw and make one.
    Video is well done, thanks for the dimensions, etc.
    JD
    Old Miller Swinger 180 Buzzbox
    Miller Diversion 165
    1945 Craftsman Atlas Lathe
    Smithy Lathe/Mill
    Jul 2007
    7
    wow what a cool mount for your band saw rig. I would like to create one of those one day.
    Jul 2008
    Houston TX
    240
    Quote Originally Posted by mikek3 View Post
    Thanks.
    It is a very worthwhile item to make because you can use the portable saw as a small table top metal cutting band saw. Of course it will also cut wood.
    I did another short video of the stand and saw showing it cutting a piece of metal and displaying a couple of views that I failed to show in the other video............pg
    http://www.youtube.com/watch?feature=player_detailpage&v=LH43dshkY_U
    Coolmate 3
    Victor O/A Rig
    Aug 2009
    Ocala Fl.
    48
    That is a nice Band Saw stand!! very nice..... Be gone Hack Saw............
    2,936
    How'd you get Johnny Cash to narrate your video
