    Bend Oregon
    62
    Default M.I.G. Welding Aluminum
    Hi, I just tried to weld mig aluminum. i get this black soot around my weld. my argon gas flow is at 25 cfm.
    Miller Maxstar 150 STL
    Miller Millermatic Passport Plus
    Thermal Dynamics Dragun Plasma Cutter
    Protect your seccond ammendment rights! Join the NRA!
    Cave Creek Az
    803
    It ain't like steel. You need to clean the aluminum well, first with a SS wire brush tehn wipe it down with acetone. You still may get some sooting, but it should wipe off with a rag.
    Jul 2007
    TEXAS
    92
    gotta push too
    pulling pulls you away from your shielding gas
    DYNASTY 200DX
    SPECTRUM 625
    MM 251
    BWE
    3,671
    Here you go. How to reduce smut...Bob http://www.thefabricator.com/Aluminu...cle.cfm?ID=554
    Jun 2007
    Camden, SC
    156
    Back your flow down to between 15 and 20. Push, don't pull. As Bob's link states, 5356 is much more prone to smut. Are you used to doing any sort of "weave" with your MIG welding to get nice looking beads? If so, be forewarned that the INSTANT you back up or cross over a hot-but-cooling weld puddle in aluminum, you're going to get smut. I get quite a bit of smut when I'm welding C channel onto corrugated aluminum pipe because of the slight gap variations and because the ripples in the base metal cause me to move the nozzle to/away from the puddle as I follow the contours of the pipe. I use 5356 for added strength and additional corrosion resistance (from possible water runoff contaminants).
    Clint Baxley
    Baxley Welding Service
    Rembert, SC 29128
