Results 1 to 7 of 7
    Oct 2011
    4
    Default millermatic 200 blew fuse
    Hi im having some problem with my mm200 I was trying to weld some exhaust and it blew the circuit breaker in the garage so I reset it and try welding again about 30-60 sec later it happen again and the machine was hot the fan came on just before it blew
    8,020
    You blew a rectifier diode
    Oct 2011
    4
    Default mm200
    So how do i and what do i need to check that
    Aug 2008
    Orange, TX
    1,215
    You're going to have to isolate the weld output rectifier diodes (disconnect them) and check to see which one(s) shorted. I suggest you replace all four keeping in mind there are two straight and two reverse polarity units.
    Do you have a Volt Ohm Meter (VOM)? If not, you'll need one. PM me an email address for a test procedure document that's too large to upload here or just Google "how to test a diode" or similar search phrase.
    I suspect your next question will be where to get replacements.
    miller4less is one place:
    http://miller4less.com/advanced_sear...90j6nt5u32s3i5
    and . . .
    . . . or do a search for those IN4048 and IN4048R numbers to find a host of sources for the 275A, 300V rated stud mounted units.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    Oct 2011
    4
    Thank im going to try that and see what happen I do appreciate the help
    Oct 2011
    4
    Thanks it works great now
    Aug 2008
    Orange, TX
    1,215
    So was it a shorted output diode??
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
Tags for this Thread
