I have (& love) my MM210; I would like to use it "portable" with my yamaha generator (650DEH) 6600 watt 220 volt.
The only issue I have is connectivity as the welder has the 3 prong and my gen has a 30 amp 4 blade twistlock.
Is it do-able?
Thanks ahead of time!
Mike
Results 1 to 8 of 8
Thread: Millermatic 210 and my generator
02-11-2008, 12:40 PM #1
- Feb 2008
- Milwaukee WI
- 57
02-11-2008, 02:00 PM #2
- Feb 2007
- Springfield, MO
- 35
yes, it can be done.......
sorry, i answered your question. again, another novel, but i wasn't thinking & sent you the answer to your private messages. but, in short, the generator plug has (2) hot legs, (1) neutral, & (1) ground. the welder only needs both hot legs & the ground. anyway, i explained it all in the PM i sent ya. but again, make sure the generator is equiped with a 30 amp breaker before doing what i told you! if i didn't make any sense just let me know. good luck! rodney
02-11-2008, 02:08 PM #3
- Feb 2008
- Milwaukee WI
- 57
Thanks guys!
I'll give it a try and will let you know if I'm welding in the NorthWoods soon.
Mike
02-11-2008, 02:33 PM #4
Here is a Pic of the adapter
02-12-2008, 10:12 AM #5
Mike,
You would want to use the 2 hot legs and the ground to power your Millermatic 210 not the 2 hot legs and the neutral. The neutral is typically used for a return for the 115 volt in a full KVA plug.
Kevin
02-12-2008, 11:12 AM #6
02-12-2008, 12:41 PM #7
- Feb 2007
- Springfield, MO
- 35
yes, yes, very true! i told him that in the PM novel i sent him, but goofed when i wrote those few lines because i was in a hurry! sorry for any confusion! i'll change it up above on my responce, just incase & PM him again. thanks! rodney
02-12-2008, 12:46 PM #8
- Feb 2008
- Milwaukee WI
- 57
Thanks for the picture; I'm going to make one as it seems easy enough!
Been trying to find this answer for months
