I have an older bobcat 225 8500 watt. Can I use a mm210 or a mm252 on it. Thanks for the help
02-11-2008, 09:05 AM #1
- Feb 2008
- 2
what welder can I run on bobcat 225
02-11-2008, 09:46 AM #2
If you have a full KVA plug, some don't, you can run the MM210, but not the 252. It needs more juice than the Bobus can put out.
Don
'06 Trailblazer 302
'06 12RC feeder
Super S-32P feeder
HH210 & DP3035 spool gun
Esab Multimaster 260
Esab Heliarc 252 AC/DC
02-11-2008, 07:57 PM #3
- Feb 2008
- 2
I was hoping I could run a mm 252 but I will go with a mm 212 or mm 210
Thanks for the help
02-18-2008, 07:00 AM #4
Hello,
The MM 212 will work off of the Bobcat, however, the MM 252 will not. Depending on how thick of material you need to weld, the MM 180 is also a good choice and more portable.Have a great day!
John Leisner
Product Manager
Miller Electric Mfg. Co.
Owner and user of:
Trailblazer 302 and Legend 301
Smith Dual Guard oxy-fuel system
Various borrowed Millermatics and Spectrums.
