Results 1 to 8 of 8
    Default at the risk of being repetitive....
    ..i've made some more outdoor furniture, lol.
    this is the first in a set which will eventually, when i find the time to build it all, comprise of 2x 1 seater benches (as per this one), 2x 2 seater benches, and 1 6 seater dining table.
    thankfully all of this lot is staying with me unlike the last two pieces.
    the benches will all be made of 304 grade 38mmx38mmx1.6mm stainless steel with a picture-framed Kwila/Merbau slatted timber top. the dining table will be 50x50x1.6mm stainless with the same timber top only accomodating 2 or 3 black granite inlays up the middle to place hot dishes/trays on.
    the tables are fully tig welded and dressed/blended in visible areas with a grinder. i like to use fiber sanding discs for the blending, it seems to help me avoid undercutting and gouging
    hope you enjoy the pics, it was a satisfying project with the picture-framed top giving it a little bit extra over straight slats i reckon
    california
    24
    gret lookling table. I love the wood and stainless together. Nicely done.
    MnT
    Salem ,Ohio
    3,936
    Cool
    Very nice...Bob
    4,435
    Agree, first rate.
    Dec 2009
    Northern California
    179
    Absolutely Gorgeous!
    What equipment are you using?
    thanks guys,
    i'm using pretty basic equipment- a standard 4x6 bandsaw, small 170amp stick/lift tig inverter, a variable speed angle grinder and a miter saw for the wood.
    there are many points along the way on these projects that i wish i'd saved up and bought a tig unit with HF start, especially doing the more awkward tacks for the tabletop bracing when i'm pretty much grinding my tungsten every tack
    Dec 2008
    west central Florida
    105
    Nice blending / polishing work at the mitre joints.
    Dec 2009
    Northern California
    179
    Quote Originally Posted by Ltbadd View Post
    Absolutely gorgeous work at the mitre joints!
    I admire your detail and the sanitary and consistent finish overall!
