Results 1 to 4 of 4
    Feb 2008
    2
    Default what welder can I run on bobcat 225
    I have an older bobcat 225 8500 watt. Can I use a mm210 or a mm252 on it. Thanks for the help
    Oct 2005
    Bulverde, Tx
    1,244
    If you have a full KVA plug, some don't, you can run the MM210, but not the 252. It needs more juice than the Bobus can put out.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Feb 2008
    2
    I was hoping I could run a mm 252 but I will go with a mm 212 or mm 210
    Thanks for the help
    Appleton, WI
    193
    Hello,
    The MM 212 will work off of the Bobcat, however, the MM 252 will not. Depending on how thick of material you need to weld, the MM 180 is also a good choice and more portable.
    Have a great day!
    John Leisner
    Product Manager
    Miller Electric Mfg. Co.
    Owner and user of:
    Trailblazer 302 and Legend 301
    Smith Dual Guard oxy-fuel system
    Various borrowed Millermatics and Spectrums.
