Results 31 to 40 of 42
Thread: flux core welding
10-15-2011, 12:50 PM #31
- Feb 2004
- 1,163
10-15-2011, 01:51 PM #32
- Dec 2009
- Williams Lake, British Columbia
- 718
Thicker then you think. Now, move along.
12-30-2011, 07:27 AM #33
- Dec 2011
- Moncton
- 4
need some welding advice.
My small tractor service business occasionally requires me to weld occasionally. I use acetylene now but was looking at something more convenient and cheeper.
Requirements:
1. Metal not more then 1/4 inch thick.
2. More portable the better.
3. Hoping to be able to use my honda 2000 watt inverter generator.
3. Rusted metal but I do have grinders.
4. Speed is not a big issue because I only weld 5 or 6 hours a month for repair and fabrication.
From what I see flux core can weld thicker materials using less input. Also can weld without doing quit as much grinding as mig. Are those statements true. Hopefully I could get away without caring around the bottle of gas.
Any suggestions?
12-30-2011, 11:43 AM #34
- Sep 2010
- 23
flux core
what i am wanting to do is have a back up on my truck if i run low on gas i carry plenty of rod and am pretty good at using them but i like mig a little better
07-31-2012, 07:17 PM #35
08-07-2012, 05:15 PM #36
Gas shielding is costly. Flux core wire is costly. What is the benefit of putting both together?
I always thought it was one OR the other.
Don't worry guys..... I'm starting a welding course at the local JC in a few weeks.
08-07-2012, 06:14 PM #37
- Feb 2012
- Wa
- 321
Man this is a rare thread on this forum. Usually people just check their egos at the door and share their direct knowledge... Lets get back to that!
08-08-2012, 07:05 PM #38
- Feb 2007
- asheville n.c.
- 595
my experience with 211 is it can crack so i use a 212 045 wire on smaller stuff. i also use 232 068 for larger stuff and for flat out speed. i can absolutely smoke 3-5 stick welders with 232. ive also used 233 but its a softer wire and can back up and birdcage in your drive roller mechanism. so i generally use 232 or 212 wire and that covers everything i do. btw im a structural welder. also do equipment welding. all my welding is outside in gale force winds
02-19-2013, 09:09 AM #39
- Feb 2013
- 3
Confusion on Changing Polarity set-up
I've just bought a new Miller 211 and I am new on this welding area. Just start learning...
Presently, I don't use Gas for welding but use only Flux Core wire. Do I need to change the Polarity that presently set up as: (DCEN)
- Work Clamp Lead connected to +
- Wire Drive Lead is connected to -
Please help me to do with it or just let it defaults to factory set up?
02-19-2013, 10:14 AM #40
