"...would use gas-shielded fluxcore, if you can. It's an all around better wire then the self-shield fluxcore...."
"...you were talking about innershield wire (gasless). You can also run dualshield wire (flux core with gas) but still...."
I thought wire was gas-shielded (from a bottle) or flux -cored (for use without a bottle)
- What is "innershield"
- Is "gas-shielded fluxcore" flux wire used with bottle gas?
- Is "dualshield fluxcore used with gas from the bottle?
Until reading this, I thought you used flux-core with the proper polarity setting and without necessarily using a nozzle for rough work, for added penetration, and for outside windy conditions. Gas (CO2, Argon/CO2) was used with a nozzle and a different polarity inside for clean work.
The discussions referenced above seem to indicate the use of flux-core in combination with gas and/or different types of shielding resulting from using flux core wire.
I'm confused. Would someone explain this to me. Things were simpler when I was a kid building cotton trailers a long, long, time ago.
Results 11 to 20 of 42
Thread: flux core welding
10-07-2011, 04:44 PM #11
- Dec 2007
- Little Rock
- 19
Educate me
10-08-2011, 07:42 AM #12
- Sep 2011
- Alberta Canada.
- 8
Never heard the term "gas shielded flux core" I think he means dual shield. Shield gas from a bottle with tubular (flux filled) wire.
10-08-2011, 08:12 AM #13
- Sep 2011
- Alberta Canada.
- 8
Inner shield just means flux cored same as coreshield. Gas shielded flux core gives better welds with easier clean up than just fluxcore by itself. More expensive process but less repairs. Any gas shield is better suited for indoors. The letter T on the electrode designation stands for "tubular" meaning flux filled wire.
10-08-2011, 12:49 PM #14
Inner shield wire is a flux cored tubular wire. It needs no shielding gas, hence the term inner shield. Dual shield wire is a flux cored tubular wire that uses shielding gas. Outer shield wire is only shielded by the gas.
I wish the random statements such as "dual shield gives better welds than flux core" would stop. Each wire used in the applications that they are made for gives the best welds for that application. I can lay very nice looking welds that pass code with inner shield or dualshield or stick. Most people that knock "flux core" have used it with a 110 migwelder & have not used it with a properly setup dialed in machine.
There is no one wire that fits all and does everything exceptional. That is why they make different ones. Pick the correct wire for the job at hand.MM250
10-08-2011, 03:22 PM #15
10-10-2011, 06:25 PM #16
- Dec 2009
- Williams Lake, British Columbia
- 722
You dont have to explain this to me.
Where I work '"in a mine on top of a mountain" we dont use gas-less fluxcore, it's just not good enough". We use it outside or inside.
If we use it outside, we tent it up.
10-10-2011, 07:05 PM #17
- Dec 2009
- 722
I haven't use much innershield wire that had all around good mechanical properties.
At the mine, we use only dual shielded inside and outside.
Outside, until you cant shield yourself enough anymore. Then we use stick.
We haven't find a practical innershielded to replace dualshielded for our application.
That's why I think dualshielded is a better all around.
But hey what do I know.
10-10-2011, 08:50 PM #18
- Feb 2004
- 1,169
[QUOTE=Daniel;273199]I haven't use much innershield wire that had all around good mechanical properties.
QUOTE]
Then you're using the wrong wires. The mechanical requirements for the T-8 wires (a self shielded FC) are the same as for the T-1 (a gas shielded FC), except for a 2% difference in elongation #'s.
J
But, the T-8 wires require considerable more skill in the workforce. All of the voltage sensitive wires are considerably more difficult to use, but they're used by the rail car load in structural steel urection, bridge construction, etc. In fact their main purpose in life is to meet severe siesmic regulation.Last edited by JTMcC; 10-10-2011 at 08:54 PM.
10-10-2011, 08:58 PM #19
- Feb 2004
- 1,169
10-11-2011, 10:10 AM #20
- Dec 2009
- 722
Before you go on and call people ignorant you should read and understand .
The engineers, where I work are telling us to use this gas shielded fluxcore "" which is ultracore from Lincoln " because it is the best for our heavy equipment repair, electric shovels and drills etc..
I think if they could they would tell us to use self-shielded fluxcore.
Plus as a bonus it doesn't spatter like most self-shielded fluxcore.
But hey, what do I know.
