Results 1 to 7 of 7
Thread: Steel finishing
    Aug 2007
    14
    Default Steel finishing
    Hey folks,
    I'm working on some indoor coffee tables and want to give them a gunmetal/burnished look without having to dip them into a bunch of crazy hot chemicals or spray paint -- I like the look of hotrolled steel but after I grind out the junctions there's the shiny bare matel next to the dark mill scale. Any ideas? The best I've found is:
    http://www.metallicfinishes.com/
    I'm working out of my garage and I'd like to keep it simple . . .
    Thanks --
    Mar 2006
    Queens NY
    1,547
    oxy fuel rosebud, heat until bright red for a minute or so and let cool.
    Aug 2006
    near rochester NY
    9,881
    there was another place posted in my to paint or not to paint posting. i'll see if i can find it for you.
    Aug 2006
    Raymore Missouri
    1,910
    I have misted some bare metal projects with a rattle can of flat black paint and when dry, lightly by hand go over with a scuff pad and then clear coat. The paint tones down the shiny areas and has a nice raw metal effect. Home Depot sells Minwax urethane clear spray cans that have UV protecters.
    Sprays easily, dries fast.
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Aug 2007
    14
    I sprayed some salt water on it and it's sitting outside . . . maybe in a few days it'll get less shiny . . .
    Los Angeles
    2,641
    Quote Originally Posted by jtn View Post
    It will soon be a nice Rust color If this is what you want it can be a nice finish- just clear coat it.
    If you don't have an O/A set up like Laiky's suggestion you can use a Mapp Torch, which can purchased at any Box Store or Local hardware store
    Sep 2007
    NE Ohio
    44
    You can use cold blue for guns. It makes a nice blue finish. Wax it with Johnson paste wax in the yellow can and forget it.
    David
