Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Los Angeles
    2,935
    Quote Originally Posted by Pass-N-Gas View Post
    No worky- you get a C-
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
    May 2009
    The Colorado Gas Patch
    185
    It worked after it was posted, If your not logged in you can not do a search.. One of fabricators links is not working now as well
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
    alabama
    750
    So I get at least a B- ????
    2- XMT's 350 cc/cv
    1- BOBCAT 250
    1- TRAILBLAZER 302
    1- MILLER DVI
    1- PASSPORT PLUS
    1- DYNASTY 200 DX
    1- MAXSTAR 150 STL
    1- HF-251 BOX
    1- S-74d
    1- S-75DXA
    2- 12-RC SUITCASES
    1- 8-VS SUITCASE
    2- 30 A SPOOLGUNS
  4. #14
    May 2009
    185
    I'll give you an A for effort
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
  5. #15
    Jul 2008
    Houston TX
    240
    Quote Originally Posted by twigster View Post
    When i open the link you supplied it just says no results found.
    Same thing happens here...... no pics.
    And it is not my computer at fault.
    The poster failed in his effort to link the pics in my view.
    pg
    Dynasty 200 DX_set up on 3 phase
    Coolmate 3
    MM 251 w/ Spoolmatic 30A
    HTP 625 Micro Cut Plasma Cutter
    Victor O/A Rig
    Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
    10 inch South Bend Lathe_3 phase
    Baldor Double Cup Tool Grinder_3 phase
    Baldor 10 inch Buffer
    Rockwell 12 inch Disc Sander
    Cyclone 2ft X 3ft Bead Blast Cabinet
    Quincy 325 2stg- Air Compressor_3 phase
    Graymills Built-in Parts Washer
    Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
  6. #16
    4,461
    One of the nicest ones I have seen was on Garage Journal, it was similar to one here and I like the features he built in, must have a real good idea to start with and it wouldn't be beyond me to tack it up for use and make changes as needed. Give it all a test run, ha. My tables are really pathetic, its not that they don't work but just kind of a cobbled mess from what I had at the time. Unless I got a real reason I don't care for huge bench and it doesn't have to be super heavy, about 3x6 or so, something easy to walk around and reach across. If it was on wheels I wouldn't bother with electric on it, park so light and utilities were convenient. Most of the time I would just as soon have a vise fixed in another spot.
    If its fixed I like a taller shelf so I can sweep under, some overhang to allow for clamping and to drill a couple holes but I like solid top. don't want crap falling thru, dirt, dust, parts, my tape or soapstone. Them things with the grates,,, not for me, great for a guy that needs it. The rare time I would need any great accuracy I could compensate for. Its got to hanger the hammers, clamps, some wrenches, shelf under for grinders and misc tools. I have the luxury of being able to bolt them to the floor, actually welded one side to embedded steel.
    One of these days I will steal some designs from here and build a couple new ones but today it wont make me any more money than the ones I got. Ha
