Results 1 to 2 of 2
Thread: Bed Riser
    Jul 2007
    Lancaster, Pa
    431
    Default Bed Riser
    I was looking at a catalog today for bed risers. I had a set of 4 under the bed but with my bed being an adjustable bed, they did not hold up to the weight. I was looking at wooden ones when my mind went into gear and said "Make them out of metal dummy" so I did. Only an hour to make 4 of them from scratch. I used 1/4" x 4 x 4 tubing that I had on stock and 2" angle iron for inside that the wheel fits into perfectly, I also put a 4" flat on the bottom so the edge did not cut into the carpet. They are 5" high and make the bed just the right height.
    I also included a pic of another plow dolly I made on Friday.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Feb 2006
    411
    Hey Ken,
    I like those Risers. . . you did a good job
    ........... Richard
