Results 1 to 7 of 7
Thread: Help ! ! ! !
    Jan 2008
    14
    Default Help ! ! ! !
    Hey guy's. I have a problem. I hooked my power up to my welder yesterday (MM252) And fed the wire into the gun like they sed. After a minute I looked and the welder was off and had no power. So I went down in the basement and one of the breakers were tripped. So I reset it, and came up and powered it back up, and nothing. No read-out no nothing. What do I do?
    What do you think could be wrong? Please help guy's
    Brookfield,MA
    103
    Is this your first try with this machine, or has it worked fine for years? If the machine is new to you and never run at this location before I would start by looking to see if you have a multi tap machine(miller makes 2 types of mig welders 1/208v-230v 2/230v-460v-575v), under the cover behind the spool of wire. make sure the taps are set up correctly for the input power and try that, if that doesn't work you know the machine is wired correctly and power is there, check your connections see if anything is loose or making bad connection. if that still don't work contact your LWS , hope it helps
    Trailblazer 302G
    MM 210 with spool gun
    Thermal Arc Heffty2 CC/CV suitcase
    Smith torches
    Porter Cable 14" carbide chop saw
    griders and hand tools coming out the WAZOO
    I owe! I owe! so off to work I go!
    Raymore Missouri
    1,908
    When some breakers trip they are kind of in a mid way position. To reset them you need to flip the breaker to the extreme off position and sharply push to the on position. Is your breaker a dual lever or two individual breakers
    used to get the 230 volt you need? If you have reset them the way you think is correct, maybe one side of the breaker is bad. Test both sides of your outlet for power if you have a volt meter and if you don't, use a lamp and test each side to ground but not across both sides or you'll blow the bulb.
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Jan 2008
    14
    I was using a 2 different breaker set-up, but I am going to try a double breaker set-up. I have power going into the power switch and coming out, then it runs to the tap, and after that I don't know whats up.
    Thanks guy's for the help. This is really a bummer. I just got it on last friday, and just hooked it up. Can you believe it a brand new welder not working.....
    DFW area
    180
    Quote Originally Posted by badassb5 View Post
    It happens, but its kind of rare.
    They check 'em out pretty well before it goes in a box and out the door of the factory.
    I'd keep chasing the problem of set up, and enough power getting to it.
    "Gone are the days of wooden ships, and Iron men.
    I doubt we'll see either of their likes again".
    Circa 1920.
    Author:
    Unknown US Coast Guard unit Commander.
    Jan 2008
    14
    YESSSSS ! ! ! I got it. I had a loose connection at the breaker. So it was showing the right volts, but when there was a draw on it, it wouldn't work right.
    Thanks again guy's for all the help
    Raymore Missouri
    1,908
    Oh yeah..........get down................and then get right back up!!!!!!!!!!!!
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    2-O/A outfits
    Jet Lathe and Mill
    Propane Forge
