I just received the steel for the 32ft gooseneck triple axle trailer I am going to build and I have a few questions. I have repaired many trailers, and built a couple small ones, but never built a 32 footer, so is there a formula for where to place the axles exactly? I figure with three axles there should be about 16 or so ft to the beginning of the first tire, and about 8ft or so behind the last tire. But Im not sure. Also, I planned to use (4) 32ft pieces of 6"x 10.5# channel (.314 thick web) spaced 14" apart and 1/8 diamond plate runners. Does that sound strong enough? The cars weigh 3200 lbs each.
My gooseneck tongue will be 10" x 15 lb(Ithink) wide flange I beams.
Any help would be greatly appreciated,
Thanks,
Christian
Results 1 to 10 of 22
Thread: 32 ft gooseneck car hauler
02-08-2008, 11:00 AM #1
Voigt Precision Welding, Inc.
Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
2007 Silverado 2500HD (tow vehicle)
2000 Camaro SS (Race car)
02-08-2008, 11:09 AM #2
I used to place mine 1' back of center. I will give you a good tip. Weld your spring hangers on some 1/2"x3" flat bar and assemble your axles and tires as a rolling assembely then you can roll the whole unit under your trailer frame and move them around to what looks right. Then just weld the flatbar to the beam...Bob
02-08-2008, 12:11 PM #3
Im using 3 5200# axles and I am going for 12,000-13,000 gvwr. The flange looks to be 4 inch, might be a tick over if im not mistaken. I only went with this since I copied the basic design from something I saw, that used 8" channel. I figure the trailer with cars should weigh between 10,500 and 11,000 pounds probably 10,500. I may try to check with an engineer if you guys think it wont be enough for a 12,000-13,000 gvwr trailer.
And thanks for the tip bob
never thought of that.
02-09-2008, 12:41 PM #4
Any other suggestions?
Just saw a 10000 gvwr gooseneck with 8"x 11.5 lb gooseneck....Voigt Precision Welding, Inc.
02-15-2008, 05:23 PM #5
Im going with the down slope..
Here are some pics of the first day...
02-15-2008, 05:24 PM #6
02-15-2008, 06:52 PM #7
One tip and i know you prob don't work by your car but, Don't let the grinding sparks hit your car glass because they don't come off they just burn in and rust in place....Bob
02-15-2008, 07:23 PM #8
02-15-2008, 07:50 PM #9
Ken
Hobart Handler 187
Dewalt Chop Saw
4" Air Grinder
Die Grinder
Rigid Drill Press
Kellogg 10hp Air Compressor
2009 FXDC
02-16-2008, 04:40 PM #10
Day 1 of the build....
