Perhaps someone can answer this question about tig filler rods based on facts.
I've seen many welders sand the copper coating from the filler rods before they will weld. I've never done this. I can't see where it makes any difference, but maybe I don't have the experiance to see the difference.
They all swear by it, and would never weld without first sanding the copper off. Anyone with a real answer? Oh and what about my 308 rods? I see people sanding those too. I hope I'm not opening a can of worms..
Results 1 to 10 of 13
Thread: tig filler rods for carbon steel
02-06-2008, 10:34 PM #1
- Nov 2007
- 14
02-07-2008, 12:21 AM #2
as i understand it the copper is vaporized by the heat needed for steel welding. i'll see if i can find that in writing for ya.
seems i remember reading it in one of my welding books, but i could be wrong. i'll look for it.
james@newyorkmetalart.com
02-07-2008, 05:55 AM #3
- Nov 2006
- Hampton, Va.
- 386
I welded nuclear pipe for over 30 years and never sanded the coating off any type of rod. I never saw anyone in the company sand any carbon steel at all and we welded miles of pipe in the reactors and outlying areas. I think it may be a preference for some in the different fields. I really don't think it makes a difference. I am sure I will hear repercussions from this but I feel sanding is not needed.
Wheelchair
02-07-2008, 06:42 AM #4
- Dec 2007
- alabama
- 722
I never have when welding pipe,although i have seen some welders wiping them down with emory cloth. unless there is a light coat of rust its pointless in my book.
see no point in any others,except aluminun wire.XMT 350 cc/cv
XMT 350 vs
TRAILBLAZER 302
MILLER DVI
PASSPORT PLUS
DYNASTY 200 DX
MAXSTAR 150 STL
HOBART CHAMP
HF-251 BOX
12-RC SUITCASES
12-VS SUITCASE
02-07-2008, 07:14 AM #5
- Oct 2007
- Louisiana
- 87
I have never done this with mild steel or stainless, but I have used scotch brite pad or emory cloth on aluminum. But maybe they know something I don't.
02-07-2008, 03:58 PM #6
some of the guys i work with do , the only reason they give is sometimes it will leave what looks like a flake of silica (for the lack of abetter word) at the end of the weld.
Miller Bobcat 250
Chop Saw
Porta-band
grinders
hand tools
02-07-2008, 04:00 PM #7
- Mar 2006
- Queens NY
- 1,547
this has been covered and i'm sure a search will turn it up. the copper is the lubricant used to extrude the wire, it also helps stop corrosion. I forget what happens to it in the welding process but as i remember it is not in any way harmful.
02-07-2008, 04:46 PM #8
lots of posts about it here.
http://www.millermotorsports.com/mbo...earchid=573176thanks for the help
02-07-2008, 06:05 PM #9
Sanding rods
All BS............just use 308 / 316./ or best yet 310 stainless for all your needs and it'll work the best .......... it's stronger then a steel weld, you have constant supply of rods , if ya need it for SS ya got it ............ and it's pure weld............
02-07-2008, 06:46 PM #10
- Nov 2006
- Hampton, Va.
- 386
Tig rods
Why would you want to use the more expensive SS rod on carbon steel as most steel is going to be painted. The last time I bought 1/16 308 tig rods at my lws they were $12.00 a lb. and 316 was much more. I am not trying to downplay what your choice may be, but it seems like a waste of money. I would not want to pass that on to my customers.
Thank you and good luck
Wheelchair
