Results 1 to 7 of 7
    Default HF 250-1 gas keeps flowing until unit is powered off
    Gas solenoid already replaced. Any suggestions?
    8,096
    Stuck contacts in CR3 relay maybe
    Aug 2008
    Orange, TX
    1,215
    Are you waiting the 15 seconds for the post flow timer to time out? 15 seconds is a long time when you're waiting.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    May 2011
    San Leon,Tx
    11
    do you have a remote switch on your torch?and is it good
    Daniel
    someone please tell me I'm wrong
    Jul 2011
    Huntington, NY
    118
    Is the selector switch set to panel or switch?
    Dec 2010
    355
    blow out the new valve with air and also blow out the hose too .i had a problem something like this and it was very fine dust that was in the hose.it doesn't take much to get a valve not to close.
    Mar 2010
    Ceres, California
    358
    sound like the post flow timer is not timing or the relay is stuck like cruzer said.
    Glenn 300 amp stick
    Millermatic 35
    L-tec plasma
Tags for this Thread
